1964-1966 GM trucks - rear sway bars & coil springs?
Discussion in 'The Hokey Ass Message Board' started by Woogeroo, Mar 23, 2013.
  1. Woogeroo
    Woogeroo
    from USA
    1964-1966 trucks - rear sway bars with coil springs?
    1964-1966 - GM trucks with rear coil springs and trailing arms
    1963 may be included in there as well, I'm not sure at the moment....
    Howdy folks,
    I'm just curious as to how it is setup and works with the coil springs and trailing arms.
    Do any of you have any experience with this?
    Have any good links to tech articles or photos?
    Thanks.
    -W
  2. GrimGreaser
    GrimGreaser
  3. Had it in my 66 chevy pickup allways rode good had alittle bounce if you hit a bump or something fast like a a dip or rail road track
  4. Woogeroo
    Woogeroo
    from USA
    Another fella posted a photo of his rear sway bar setup. It has brackets on the frame rails, then a rod that drops down to the bar, the bar connects to each rear trailing arm.
    kinda nifty... if needed.
    -W
  5. Nailhead Jeff
    Nailhead Jeff
    from fresno
    Go scrounging for a 1968-1972 Camper Special in the wrecking yard. Those have factory rear sway bars.
