Need small block starter advice
Discussion in 'The Hokey Ass Message Board' started by Rusty Karz, Mar 23, 2013.
  1. Rusty Karz
    Rusty Karz
    I put a 1955 chevy three speed and bell housing on a 1975 350. When I went to mount the starter from the '75 it wont fit into the bell housing. What do I need to do? Whole different starter or different nose piece? I know this is kind of a rookie question but that is where I am right now.
  2. best2923
    best2923
    from north Id
    should be able to change the nose out to the old 3 bolt one.
  3. wallyracer449
    wallyracer449
    i think a 3/4 ton or 4 wheel drive use the correct starter also
  4. black 62
    black 62
    from arkansas
    just need the right nose---sometimes hard to find...
  5. HOTRODPRIMER
    HOTRODPRIMER
    Most towns have a starter/alternator shop,,they should have the parts you need. HRP
  6. Stick shift cast iron snout is smaller than the aluminum automatic trans starter snout to get you the clearance you need.
  7. 56sedandelivery
    56sedandelivery
    Sounds like you are using a block mounted starter with a bellhousing that was designed to have the starter bolt to it; make sense? What most guys do, and I HATE this happening, is to cut, remove, knock off the innermost bolt hole tab on the bellhousing starter mount. That usually gives the needed clearance. IF you're using a 168 tooth, 14 inch diameter flywheel, they I'd use a bellhousing mount starter; if you have the smaller 153 tooth flywheel, then you're going to be stuck with using a block mounted starter, and time to get out the O/A cutting torch, BFH, or hacksaw, and cut the bolt hole tab off the bellhousing (another one sacrificed). Butch/56sedandelivery.
  8. 40Standard
    40Standard
    from Indy
    should be able to just change the starter nose
  9. Harvey29
    Harvey29
    from kansas
    Is a mini starter out of the question? They don't use a nose cone.
  10. 65PANELRAT
    65PANELRAT
    BINGO! This is exactly what I am using on my 56' Bel-Air 3 speed manual, and 327 sbc.
  11. Rusty Karz
    Rusty Karz
    What is a mini Starter.
  12. 65PANELRAT
    65PANELRAT
  13. Rusty Karz
    Rusty Karz
    That looks like just what I need. Thanks.
