does anyone know what the diffence is in a 99 and down rear wheel to a 2000 and newer rear wheel on the softails? I know some of the newer ones have a 1 in axle and some have the 3/4 axle. but will the rotor and sprocket fit from a older wheel to the newer one?
I do believe you may wish to try the Jockey Journal. Like this but fer motorsicles. Then again, someone here will probably know...
they made some changes. i heard about the 1 inch axle but never saw one on a softail, but i could be wrong. caliper mount is different. i think they went to a sealed bearing in 2000. when did they change to the skinnier belt? i don't know, everyone i ask can't tell me either.
the spacing on the inside of axle is different,, the rotors are the same , however you will have some clearance probs with the rotor ,, alot of cahnges also the later models have a different off set for wides tires,, according to want year you are using,,
Sometimes ya get lucky. A shop had a rear wheel from a late 90's duece or some ****. I Put it on the fromt of my stock '75 FLH using my old spacers. fit great.
