Need help with 6 volt positive ground.
Discussion in 'The Hokey Ass Message Board' started by Doodsie, Mar 24, 2013.
  1. Doodsie
    Doodsie
    I've been a Ford guy all my life, never owning one older than '63. I just picked up a remarkably complete '51 Chevy, right down to the air cleaner, spare tire, jack, etc. I know it is a six volt system, however it had a 20 year old Ford twelve volt battery (group 78, I think) in it, BUT not hooked up. The voltage regulator is still six volt. I got the correct 6 volt battery yesterday, but I'm afraid to go too far. I've been told mine is a positive ground car, but the starter cable wire has a terminal end opened wider for a positive battery terminal and the block cable has a terminal end smaller for a negative battery terminal. So in theory my positive cable should go to the block, the negative to the starter, but I'd like to confirm that for certain. I have the head on the bench to free up a couple of sticky valves, and to find out why the crank won't turn. Marvel mystery oil and a flywheel wrench solved that, so I want to try the starter. Just tell me for sure it's positive ground, and from there I'll see if any damage was done to the electrical system.
  2. GREASER815
    GREASER815
    It is not a positive ground. Negative should go from battery right to by the thermostat housing.
  3. GREASER815
    GREASER815
    Is ground strap braided and more toward the front of the car? Should be, and positive toward rear of batt tray and right down to the solenoid
  4. Nailhead Jeff
    Nailhead Jeff
    from fresno
    Fords from that era are positive ground.
  5. plodge55aqua
    plodge55aqua
    from Alberta
    Old Mopars from that era are as well. right up to 1955.. Positive ground..
  6. And TV sets were black and white Stay on point.
    Your Chev is negative ground, as was pointed out. Even if you hook it up wrong, you wont hurt anything except, maybe, the radio.
  7. Hnstray
    Hnstray
    from Quincy, IL
    X2
    Ray
  8. cornbinder52
    cornbinder52
    It must be a common misconception because my 50 was hooked up positive ground. It's negative.
  9. big vic
    big vic
    from cary il
    51 chevy negative ground positive to the starter
  10. Rusty O'Toole
    Rusty O'Toole
    Hook it up wrong and your horn will **** instead of blow ha ha ha not really funny joke.
  11. simplyconnected
    simplyconnected
    If you connect your starter motor EITHER WAY, it will go in the same direction because the armature and field wires are connected internally. If you reversed either, it would reverse rotation.
    Generators and regulators; same story. They can be either pos or neg gnd as there are no diodes or solid state devices inside.
    The heater motor will go backwards if connected wrong if it has permanent magnets.
    Heat-activated Fuel and Temp gauges don't care which way the batt is connected. If the radio has an original mechanical ********, it can be wired either way. Most clocks were solenoid-wind, so they don't care, either.
    Magnetic meter movements will try to go backwards (if you have any).
    Some folks ran their batteries backwards for years, and never knew it. Check the books for the correct polarity. - Dave
  12. Doodsie
    Doodsie
    Thanks guys, great info. I guess now I need to worry if it was run on 12 volts, but visually the wiring looks to be in great shape. Oh, it has no radio. Or turn signals. It's about as basic as it gets! I'm taking baby steps with this thing, and so far so good. Engine's freed up and looks decent enough inside, and the valves now all snapping shut smartly. I'm glad I pulled the head - no bent pushrods or valves to replace! Hope my horns blow instead of ****! BTW, the H.A.M.B. seemed to be well represented at Billetproof Saturday.
  13. Doodsie
    Doodsie
    How come I can't find a fuse panel?
  14. Hnstray
    Hnstray
    from Quincy, IL
    'cause there ain't none..........:D
    Ray
  15. GREASER815
    GREASER815
    Yep, mine had an add on gl*** tube type panel right under the dash drivers side. Rip all that **** out, go 12 volts and save the headaches. Well worth the time and money. Look into the 9+3 harness from Rebelwire, I used it in my car and it is great.
  16. actually on the Delco regulator it will say which ground it has on the side by the number and the regulator points will fail quicker if reverse polarity
    OLD and not totaly senile YET
  17. Atwater Mike
    Atwater Mike
    12 Volts won't hurt the wiring...it's larger gauge than 12 volt systems use. (heavier gauge carries more amperage for less resistance at lower voltage)
  18. junkyardjeff
    junkyardjeff
    The only GM vehicle that was positive ground is a 6 volt GMC truck and dont know for how long they were made that way.
  19. manyolcars
    manyolcars
    wanna know if your car was set up for 12V? Look at the headlight and tail light bulbs. My avatar had 12V bulbs everywhere
  20. simplyconnected
    simplyconnected
    You just beat me to it.
    Your car may have been converted to 12 volt. Check the bulbs and the heater motor. Twelve volts will work just fine on a six volt starter motor, but it will quickly burn out six volt lamps. - Dave
  21. Doodsie
    Doodsie
    Thanks again to all who responded. The regulator's aftermarket, but I'll check it. The headlights work fine on 6 volts, as does one taillight. The other's dim, so likely a 12V bulb. I've got a service manual headed my way (good old eBay), so I shouldn't have too many more dumb questions. The dash lights don't work, that's why I was looking for fuses. I'll worry about that junk once I get the engine running, and rebuild the hell out of the brakes. Can't wait to get this old tub of **** on the road!
  22. GREASER815
    GREASER815
    Have any pictures of the car?
