1931 and 1932 Ford Roadsters
Discussion in 'The Hokey Ass Message Board' started by LilGTO67, Mar 15, 2013.
  1. Dreddybear
    Dreddybear
    There's more complexity to ***embling them. Some more welding and what not that comes out in the final price. Both make awesome hot rods.
  2. HellsHotRods
    HellsHotRods
    How can it be your "dream" when you know nothing about it????
    Just get yourself a cheap 32 fibergl*** body and some billet parts and your dream will come true.....
  3. chevyfordman
    chevyfordman
    My 32 doesn't have a diaper, and I still have a full trunk area.
    3931932
    Or you could own one of each...
  5. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Is this considered a full diaper?
  6. ljones44
    ljones44
    from Atlanta
    The 32 body pobably has a better resale. Regarding room unless you plan to have more than two people in the seat area, then room shouldn't make the difference. The door on the 30/31 overlap so door adjustment isn't so critical. Gas tank also should not be a factor.
    Frame appearance depends on whether the car will be full fendered or the high boy look, regardless the 30/31 body will fit on a 32 frame with a little alteration to the frame.
    Personally, 4G's is a big nut and I would look for someone that wants to sell a slightly used Brookville body.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Well, I am a '32 guy,no if's and's or buts,,,if I were to build a roadster other than a Deuce it would be a 29 on 32 rails,,,they just look like hot rods. HRP
  8. racemad55
    racemad55
    Don't forget your frame horn covers!
  9. 26 T Ford RPU
    26 T Ford RPU
    I agree with you HRP,'29 on a '32 frame is damn fine. I had a steel '32 roadster in the early eighties but like '28-'29s a bit more now and my RPU a bit more than that. JW :)
  10. Drive'em
    Drive'em
    Here's my 2 cents worth. I think a 28-29 body on 32 rails is the way to go. It looks sleeker and the body doesn't look as fat as a 30-31 or 32. To me the curved and sloping cowl is way cl***ier than the straight hood on 30-31 & 32. I guess you can tell I'm a 29 guy.
  11. Like NHRA founder Wally Parks-
    pivir123 likes this.
  12. Can't believe someone is at the point of purchase and doesn't know the difference between a 30/31 and a 32!
    Houston we have a problem LOL
