Rear sway bar
Discussion in 'The Hokey Ass Message Board' started by EnglishBob, Mar 23, 2013.
  1. EnglishBob
    EnglishBob
    Putting either a 9 or 8.8" and parallel leaves under the rear of my 42 Tudor and getting ready to cut all the original brackets and hangers off.
    Do I need a sway bar?
    Cheers
    Bob
  2. sidevalve8ba
    sidevalve8ba
    With parallel leaf springs you do not have to have an anti-sway bar. The springs locate the axle side to side. That being said an anti-sway bar will reduce body roll and in my opinion the car will handle better.
  3. hoop98
    hoop98
    from Texas
    The balance of the car (understeer or oversteer) depends on the balance of front and rear "roll stiffness". If the car understeers, adding a rear anti-roll bar make the car more neutral.
    If the car oversteers it will make it worse.
    You need to drive the car in a large circel in a parking lot, to check the balance.
    Hoop
  4. EnglishBob
    EnglishBob
    Can't drive it till the rear ends in???:confused:
  5. HOTRODPRIMER
    HOTRODPRIMER
    I drove a 40 sedan for several years and it had parallel leaves,,,after I added a big sway bar I got from Ch***is Engineering I was amazed at the lack of body roll,,big improvement. HRP
  6. Kerrynzl
    Kerrynzl
    If you want to eliminate any sort of panhard or watts linkage just toe the springs in [ no longer parallel ]
    If you want a really soft ride [ as in soft springs ] you might need an anti-roll bar.
    If your springs are quite stiff you need less bar or none at all.
    Understeer, oversteer is controlled by "Roll Couple" which is the relationship between front and rear roll stiffness.
    When at the limit of adhesion the stiffest end always slides out first
    Personally on a street car I would not run a RARB [rear anti roll bar] until I have spent more time selecting the correct stiffness springs.
  7. EnglishBob
    EnglishBob
    Using a TCI bolt in kit specific to the car so Im guessing springs are pre tested and ready to drive on.
    Ok another way maybe,anyone know of a bolt on sway bar set up so I can install
    'After the fact' in need be?
  8. Bert Kollar
    Bert Kollar
    I have sway bars on two rods and planning the third wouldnt build a car without them greatly improves handling and stability
  9. ,,,,,,,,,,,,,for those who don't have the 'deep pockets.'
    A factory, REAR, sway bar ***embly, from any full sized Ford Bronco ('80-'96) or the F-150, or F-250 PU's, is almost a direct bolt in, on ANY parallel spring, frame or unibody vehicle! (Bronco bars are a little wider than the F-Series bars. Same shape, and mounting)
    The OM Bronco/F-Series sway bar link bolts will need to be shortened when on a lowered car. Same way, the OM Bronco/F-Series sway bar, rear end housing mounting plate. One can 'trim' them down to look a little neater.
    On unibody frames, a steel bushing will need to be welded inside, so the OM link bolt frame mounting bolt will not collapse the unibody frame.
    ANY parts store has either a replacement urethane, or poly-urethane bushing kit. (the replacement busing kits will probably cost more than what a junk yard or a U-Pullit will charge for the entire swaybar ***embly!)
    A upgraded front, AND rear swaybar, will make a 'night/day' handling improvement!
  10. langy
    langy
    If you fit a rear bar you should fit a front as well, ok to have just a front though.
  11. 296 V8
    296 V8
    from Nor~Cal
    Keep your stock spring w PJ style ladder bars
  12. fordor41
    fordor41
    Ditto here as far as body roll BUT made the ride rougher, especially on one wheel bumps. Extra stiffness caused the body to jump up, badly.
  13. Unkl Ian
    Unkl Ian
    Need ? Not really.
    Want ? I would.
  14. black 62
    black 62
    from arkansas
    i have run my car with and without a rear sway bar---no difference ,but my springs are pretty stiff and the car is light---easy to add if you are not happy...
  15. fiftyv8
    fiftyv8
    from CO & WA
    Which are we talking about, I feel we are not all on the same page.
    This is a panhard bar;
  16. fiftyv8
    fiftyv8
    from CO & WA
    Or do we mean one of these a sway bar???
  17. fiftyv8
    fiftyv8
    from CO & WA
  18. black 62
    black 62
    from arkansas
    common vernacular includes both types ...
  19. 57210
    57210
    I'll always remember that if you go off the curve forward, that's under steer and if you go off backwards that's oversteer
  20. hoop98
    hoop98
    from Texas
    Or if you hit the wall with the front it's pushing, with the rear it's loose.
    This should make it easier to understand...
    "That's a joke, I say, that's a joke, son."
  21. black 62
    black 62
    from arkansas
  22. hoop98
    hoop98
    from Texas
    Question, why would I add a rear sway bar after converting from transverse leaf to parallel leaf.
    Answer, you have substantially lowered the rear roll center making the rear much softer in roll.
    Unless you lower the front roll center or raise rear roll stiffness this will unbalance the car.
  23. tinmann
    tinmann
    Sway bar? For a second there I thought you said gay bar, Bob. Gotta go.... Coronation Street is on the telly. Pip pip.
  24. mgtstumpy
    mgtstumpy
    Worth the effort installing F&R sway bars IMHO. Used them on all my cars. Better road manners and a pleasure to drive over No sway bars.
  25. DoubleJ52
    DoubleJ52
    from Belton, MO
    I have a rear sway bar with leaf springs in my 41, and front bar as well. All Ch***is Engineering stuff. Rides and handles well. If you have leaf springs in the back you don't need a panhard bar.
  26. hotroddon
    hotroddon
    Can't say I have EVER heard anyone call a panhard bar a sway bar - they don't come close to doing the same function. Now panhard bars are called track bars (NASCAR Term for them), Locator bars, or even lateral locator. The idea of these is to keep the rear end (or in some cases front axle) center (more or less) in the ch***is
    Sway bars are more correctly called Anti Sway Bars and have also been called Roll Bars/Anti Roll Bars and maybe even stabilizer bars. These are designed to remove body roll and to help balance the roll stiffness between the front and rear of the car.
  27. 296moon
    296moon
    from england
    What is this antiroll/sway bar from please
  28. A Rodder
    A Rodder
    I ordered the biggest front and rear anti roll bars from Hellwig for my 56 wagon.
    Should have them on within a few weeks. .
    I had a 57 wagon about 5 years ago with them and it handled waaay better than my current 9 p***enger wagon.
  29. Cosmo49
    Cosmo49
    You are The Dude, thanks for the information!
  30. Kerrynzl
    Kerrynzl
    Oversteer frightens the p***engers
    Understeer frightens the driver :D
