Hot Rods Jeep utility
Discussion in 'The Hokey Ass Message Board' started by milspec85, Mar 25, 2013.
  1. milspec85
    milspec85
    from Spokane WA
    All
    Im looking at a Jeep Utility wagon project but am wondering if a stamping for the side panel with the rounded wheel wheel opening and no windows is available anywhere? Would perfer the panel version. I have two Jeep wagons available (49 and 52) to begin my project and am thinking of a early 90's Roadmaster or Caprice wagon for a donor vehicle would be a good start.
    Anyone done a front clip on these wagons? Could the Caprice/roadmaster work or too wide (yes, i know these vehicles have a full frame)? Seem to wide at first glance but perhaps not as these GM vehicles were downsized and werent too much bigger than the older Chevelles 1967-1975. Would prefer of course to have the the same front and rear bolt pattens and not get too many differnt vehicles involved for the drive train transplants. Perhaps Mustang II is the only way to go to get a decent power steering unit and frame geometry. Give me some input guys....:mad::)
  2. manyolcars
    manyolcars
    this used to be a traditional hotrod forum
  3. bulletproof1
    bulletproof1
    from tulsa okla
    the axles are pretty narrow on these trucks...ive seen S10 frames under them done pretty nice. closer width,tons of aftermarket parts and cheap to boot.changing frames,axles and customising is a big part of traditional hot rodding...
  4. plodge55aqua
    plodge55aqua
    from Alberta
    The problem with most other Forums.. is there just plain Dead.. ask a question wait a week or two for a reply.. maybe longer..
  5. willymakeit
    willymakeit
    Haveyou looked at using a 2 wheel drive Cherokee straight axle in front? 4.5X 5 bolt pattern disc brake. They also have power steering. I know its not a independent but with reversed eyes, teflon ****ons ect. you can get it down and receive about 75% of a independent. Dont forget a anti roll bar to.
  6. willymakeit
    willymakeit
    Add a explorer rear with disc brakes and it will match in bolt pattern also.
  7. metalshapes
    metalshapes
