F100 door seals suck
Discussion in 'The Hokey Ass Message Board' started by ugotpk, Mar 26, 2013.
  1. ugotpk
    ugotpk
    Anyone have a good idea to seal the wind noise out on a 56 F100. None of these trucks had doors that fit very well. My doors are in the correct position. Seals are new and soft. Doors close tight. Still have wind noise. Please only answer if you really know what the hell you are talking about. And no I'm not going to weld my doors on. PK
  2. HOTRODPRIMER
    HOTRODPRIMER
    I don't know what the hell I'm talking about but who's door seals are you using? HRP
  3. Carbs & Chrome
    Carbs & Chrome
    On my '56 I thought it was my door seals, but turns out it was leaking around the vent windows.
  4. 55 dude
    55 dude
  5. jstanotheidiot
    jstanotheidiot
    Turn up the radio!
  6. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    ha ha ha same here !!!
  7. ugotpk
    ugotpk
    Dennis Carpenter Seals
  8. Flingdingo
    Flingdingo
    This!
  9. texasred
    texasred
    from Houston
    I used STEELE seals on my 53 and 56 with no problems. they just cost a little more than dennis carpenters
  10. If wind is blowing into the cab, then, yes, you have a problem with the seals or door alignment. If it's just wind noise, then it is a matter of aerodynamics.
    I hope I meet the criteria, of knowing what the hell I'm talking about, as public scorn causes me such emotional pain:p
  11. ugotpk
    ugotpk
    All my H.A.M.B. buddies. God you got to love um.
    No its not vents. It's not holes in the floor, It's not the cowl vent or the heater fan on to high, Just door seals....And no more out of you 55.
    P.S. it's not the wind from the inside either.
  12. Barn Find
    Barn Find
    from Missouri
    You can also try adding a seal around the outer edge to fill the gap between door and body. All new cars and trucks have an outer seal for aerodynamics. There's no reason why you can't add that to your F100.
  13. aerocolor
    aerocolor
    from dayton
    That`s what I did. Added peel & stick 1/2 " to the door tops inside to seal `em off. Door alignment was spot on but could see gaps of light after installing seals. Stopped the rattle over bumps too.
  14. Hackerbilt
    Hackerbilt
    First thing you need to do is find the air leak.
    Pick up some "leak Trace powder" (it comes in a spray can...try autobody suppliers.) and apply it to the painted areas the rubber door seals contact. (Don't spray it on the seals!)
    It's a simple and harmless concentrated white powder.
    Very gently push the door closed (don't just slam the door) and then when you reopen the door you will see the white witness marks on the black door seals to tell where the seals are sealing properly, but more importantly where they aren't!
    What you choose to do to FIX the problems will depend on just what you find the issue to be.
    Don't forget to check for small open voids in the external areas of the doors/frames and also the cowl and roof areas as they can also cause some suprisingly loud wind noises to enter the cab.
    As Carl said...its all about aerodynamics and air flow so don't ***ume it isn't somewhere other than the seals.
    You could be very surprised when you finally discover just what the problem really was!
  15. gasmanm01
    gasmanm01
    i know i dont know what the hell im talking about, mines noisy and leaks air. i just crank the tunes up
  16. tiredford
    tiredford
    from Mo.
    On my 53, the doors fit probably as good as they did when new (not perfect). I tried seals from DC and mid 50 and never did get it perfect. The wings are a trouble spot and the windshield. I tried everything on the windshield, including taking it to a gl*** shop and it still leaked water in the lower corners. Sorry, not much help, just my experence.
  17. RatPin
    RatPin
    Louder pipes!
  18. I never thought they were that good when new.
  19. Fopelaez
    Fopelaez
    You can use a compressed air nozzle and have some one blow air by the perimeter of the door, vent and maybe fender sides while you, from the inside, check where the leak is?
    Fernando
  20. 54 Chevy
    54 Chevy
    Check with Softseal they make several types of universal seals they may have one that is taller and will seal better.
  21. Gotgas
    Gotgas
    from DFW USA
    This is an old bodyman trick.
    When you align a panel, especially a DOOR, make 100% sure that its leading edge "tucks in" slightly from the panel in front of it. If it has even a small part that catches the air, it will whistle and make a mad customer. The trick is to make it subtle.
    If you want to test it first before committing to moving everything around, get in it, have someone put some 2" tape over the door gap, and go for a drive. See if the howling changes or goes away.
  22. ugotpk
    ugotpk
    That's a good idea Fernando. Thank you!
    II will check out your method Aerocolor. Thank you too.
  23. willymakeit
    willymakeit
    X2, this very important on a 56. Ive bent and twisted the window area ans stopped it. [Very subtle] Sometimes you have to live with it.
  24. Dreddybear
    Dreddybear
    Send it over. I know how to fix it..
  25. 40FordGuy
    40FordGuy
    Window channels........
    4TTRUK
  26. DICK SPADARO
    DICK SPADARO
    I have the same suggestion as Gotgas, post #21 The majority of door leaks, windleaks or noise, come from the front or leading edge of the door being above the body line. This leading edge picks up the airflow and redirects it to the interior. In most case its a noise you hear rather than an air flow as the breeze is altered by the angle of the door jambs. Follow his suggestons about using painters tape on the door edge to determine if that is the source of the leak.
  27. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    Or slow down.
  28. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    that's funny as hell! Thanks for the laugh
  29. 32Tudor396
    32Tudor396
    I used to drive a couple early sixties Merc pickups,A body man I know solved my problem by one knee on the door and a slight pull of the top front corner.It Didn't take much but it tightened the seal up.I have done a few times with good results.
  30. Ralphies54
    Ralphies54
    I to had a huge amount of wind noise till i did as Aerocolor did and double weatherstriped the door jambs by using pealandstik 1/2" 1/2round sponge rubber I got from Restoration Supply Co. I applied it to the jamb area and it did the trick. Very quiet till the cowl vent is opened at speed,then all that air trying to get out makes a hell of a noise around the doors. End up using the A/C most of the time.
