home made tools and equipment...
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Jan 16, 2008.
  1. 87Heaven
    87Heaven
    Nice going on the Clamp 3D kot...And welcome to the HAMB.:)
    The reason we make that kind of stuff is the same reason we come to the HAMB.:D
  2. jazz1
    jazz1
    Nice job,,, I bought a few couple years ago as i was leery of their quality as I had never seen them before(i dont get out much) It would be easy enough to make some up for larger projects using maybe 2" square stock.. Or make one out of the biggest diameter square stock you can find just to hang in your shop.
  3. kevtsi
    kevtsi
    wow Ive been going through this thread for what seems like a week. I really enjoyed all of the awesome tools. Of all of them the rotisserie's are what have me wanting to make first. Roughly how much weight can be put up on these?
  4. Jim Stabe
    Jim Stabe
    Mine is not the most robustly built of all the ones I have seen here and other places but I can still put my ***embled MGB on it (about 2,000 lbs) and it holds it fine. Some of the stronger ones should handle twice that with no problem.
  5. Buzznut
    Buzznut
    Love the STORAGE SPACE you fabbed into that ch***is...
    Seriously, took me a second to realize that all of that was spray paint and stuff on the shelves behind the rotisserie.
  6. Jim Stabe
    Jim Stabe
    Yep, that's pre-floorboards
  7. Mattbee
    Mattbee
    I've been looking at making my own tubing bender. Has anybody made one using a pneumatic air cylinder instead of a hydraulic cylinder? I have a couple laying around and was thinking about using if is possible. Does anybody have one that they made themself?
  8. porsche930dude
    porsche930dude
    I wanted a verical bench belt sander so I made this stand for one of my many extra belt sanders
  9. jalopy45
    jalopy45
    How long before someone mentions the belts are running horizontal in the photos? :D
  10. only vertical in the mid west, he's on the east cost , mine goes the other way being im on the left coast , lol :rolleyes::D
  11. backwoods96
    backwoods96
    from Mead, Wa.
    Mine fell over so it is running horizontal ---------------
  12. nmpontiac
    nmpontiac
    from Taos, NM
    I wanted to work on my 50 Pontiac's doors, so I welded a couple pieces of 1 1/4" tubing onto the legs of my small fab bench then made a couple of "L" shaped pieces to fit in them. A piece of foan pipe insulation on the top edge of the bench and it was done. I did have to grind the seam down in the 1 1/4" so the 1" slid easily.
  13. willymakeit
    willymakeit
    Check Pirate 4X4 forum. There is a guy by the name of Takas (?) who sells a nice set of plans. Air over hyd.,uses pro bend dies.Works in the vertical fashion. I have the PDF and am in the process of building it.
    Hope this helps.:)
  14. olcarguy
    olcarguy
    Air will work ....however the size of the cylinder required would be HUGE, as in really really freaking big....
  15. LowerthanLife
    LowerthanLife
    what do you use the chainmaille for??
  16. porsche930dude
    porsche930dude
    the chainmaile is a bit of an expeariment really. i used it to cover the seat you see nexto it for this bike. time will tell if it suits the bike or not
  17. Buzznut
    Buzznut
  18. southpaw-customs
    southpaw-customs
    Not a home made tool , but a improvement. I stored my sandblaster in a unheated storge shed. I went to use it and the sand had drawn moisture and became clogged. I had to dis-***emble the lower part and then shake the sand out of it. That took some time. When I got ready to re-***emble it I had a heck of a time getting the sandblast hose screwed back in. I solved the problem by adding a union and now it is easy to get the hose off of the unit with out having to untwist the hose. The hose has crimped on the ends and I didn't want to cut them off and use hose clamps.
    It might even be handy if you are changing media. Just unscrew the hose and capture the unused media in a container instead of blowing it through the nozzle.
      55 KB
      55.5 KB
  19. Harvey29
    Harvey29
    from kansas
    I built a jd square model 3 only cost like $100 in material
    Sent from my DROID device using the TJJ mobile app
  20. harmless
    harmless
    Great Idea, thanks for posting
  21. porsche930dude
    porsche930dude
    i made this sheet metal bender. works pretty good as it is but i think i need to add some support bracing in the center for thicker stuff
  22. Don's Hot Rods
    Don's Hot Rods
    from florida
    This certainly isn't the most sophisticated homemade tool ever built, but it does the job. It was always a pain to put early Ford front brake drum/ tap in dust covers in place for me. I would tap around the edge with a screwdriver and hammer so I wouldn't dent the dome on the cover, but that left a lot of scratches and took a lot of time. So I built a simple tool to install them.
    I took a piece of s**** 2.25 diameter steel tubing and sliced a piece out of it a few inches long. That size fits perfectly over the Ford dust cover and yet is small enough to catch the lip that runs around the cover. To that I welded a piece of flat stock steel so I could have a flat surface to smack with a hammer, and I also welded a piece of round stock on for a handle, so my hand was away from where I was striking.
    To install the cover (some people call them a grease cap/bearing cover) you simply start the cover into the hole in the brake drum hub, then squarely put the round part of the tool over the cap and smack it with a hammer a few times to drive the cover into the hub. I found that if you slightly bevel the leading edge of the cover a little it will start into the hole better.
    Since building this tool I have never dented another cover and they always go right in without any ****ing in the hub, and it took all of 15 minutes to make the tool. The hole in the flat plate is simply to hang the tool up when not in use.
    Don
  23. RMR&C
    RMR&C
    from NW Montana
    Here's a couple I made....
    The brake will bend 18 ga a full 48" wide, and 16 ga in shorter lengths. I have about $50 in it, most of the metal I had laying around. I plan on adding some counter weights to it when I have time.
    Second one is a masking paper dispenser I made from a bunch of pipe fittings and a couple old lawnmower wheels. It has an old hacksaw blade to rip the paper off. Works great, I've been using it for years.
    I have a lot of fun designing and making my own stuff.
  24. bobj49f2
    bobj49f2
    Don, that is so damn simple but a great idea! I'll have to throw one to together.
  25. Low350
    Low350
    from Australia
    Hey Guys, awesome thread! I'm totally inspired to go and build some sweet tools after spending the morning going through most of these posts!! I've only made a few small tools but they've certainly been super useful!!
    A long reach dolly from an old hi tensile bolt...
    Turned the head down on a lathe and then hit it with a sanding disc before polishing it with various grades of paper by hand..
    Works a treat!
    Also made this ******* from an old file..
    Heated it and bent it with the oxy, then added some electrical heat shrink for a more forgiving handle.. :)
  26. atch
    atch
    don - great job. i like the handle a lot; wish mine had a handle. i think i'll add one.
    bob - if/when you make yours consider using a PVC pipe fitting where it touches the grease cup. i made mine doing that and i've never scratched a grease cup since (although i imagine that by striking the cup all the way around instead of in just one place probably wouldn't scratch one with one made from a steel pipe/tube).
  27. tooljunkie
    tooljunkie
    from manitoba
    i made a dust cap driver a long time ago,as i cant stand a bent up dust cap.
    they like to fall off when they are mashed on with a hammer.
    i service a lot of trailers,all travel thousands of miles on gravel.a pristine cap stays on longer.
    if the part that touches the cap is smooth,it is less likely to mar the cap.
  28. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
    Man I think the work Done here is great, But I have to ask, What in the hell would you do with a 36 inch Bowl??.....I mean that would be like 8 boxes of "fruity pebbles" and 4 gallons of milk........LOL
  29. roseville carl
    roseville carl
    make a good drain pan<!-- / message --><!-- sig -->
    __________________
  30. 3d_kot
    3d_kot
    Hello everyone :). Sorry for offtopic, but I decided to show how I improved my welding helmet. LED lights were bought on ebay)
