348 in a 1957 Chevy Napco Truck Ideas
Discussion in 'The Hokey Ass Message Board' started by donsz, Mar 28, 2013.
  1. donsz
    donsz
    I have a 1957 Chevy Napco truck (see avatar) with a 283 and 3 speed OD trans. Now that it is done, I would like to swap out the 283 with a 348 I have (1965), that I will re-build to a tri-power configuration. Also, I think I would like to install T5 trans at the same time. The 283 is my third engine and is just fine, but I just want a "W" motor, "just because." I was wondering if anyone has experience with this swap. It seems like the exhaust to steering box clearance is an issue. But, I think that the 348 was an option in 1958/59 trucks. So I'm wondering if there was something different about the exhaust or steering box for those years. Also, I think that the 348 should hook up to the V8 bell housing that I have now. And if that is true, then a T5 should mate OK? I'm guessing I may have to do something with the yoke/drive shaft though. Any thoughts would be great.Thanks,
    don
  2. bobwop
    bobwop
    from Arley, AL
    why wouldn't you stay with the stick/OD? I love those trannies. And it would be a very easy swap, too.
  3. amodel25
    amodel25
    Not familiar with a Napco. Is the transfer case entirely seperate from the main transmission?
  4. 56sedandelivery
    56sedandelivery
    You can use the same flywheel, clutch ***embly, and there should be plenty of room for exhaust (not like in some p***enger cars, 55-57). I'd stick (no pun intended) with the same trans also, but they are weak. I once snapped the input shaft just leaving a stoplight "normally", with a 265 in front of it. It's a separate transfer case right? There should be no problem using a different trans then, but you have to change the yoke and possibly modify the driveshaft to the transfer case. Butch/56sedandelivery.
  5. black 62
    black 62
    from arkansas
  6. donsz
    donsz
    Yes, a truck block, last year of manufacture, I believe. According to the 348/409 site a good one to rebuild. The transfer case is divorced, ****er 23, stock NAPCO component for that year.
    don
  7. black 62
    black 62
    from arkansas
  8. Don't know any specifics but it seems an awesome repower.
  9. an1951
    an1951
    A 1965 348 chevy engine? Maybe up to 1964 in a truck only.
    From Wikipedia:
    The first ever production big block V8 Chevrolet engine was the "W" series, released in 1958 for p***enger car and truck use. This engine was an Overhead valve design, with offset valves and unique scalloped rocker covers, giving it a distinctive appearance. The "W" series was produced from 1958 to 1965, with three displacements offered: 348 cubic inches (5.7 L), available from 1958 to 1961 in cars and through 1964 in trucks; 409 cubic inches (6.7 L), available from 1961 to 1965; and 427 cubic inches (7.0 L), available only in 1963.
    Website-interesting stuff:
    http://en.wikipedia.org/wiki/Chevrolet_Big-Block_engine
    My 2 cents worth and I'm A Chevy Drag Racing Fanatic.......
  10. I have a 58/9 Big truck with a W in it. I'd take pics, but unless you like winter scenes, it won't do you any good at this time. (the snow is still overwhelming in my yard)
  11. raengines
    raengines
    from pa.
    back in 65 I put a tri-power 348 in a 55 chevy wagon to tow my race car with, fit like it was born there.
  12. 38Chevy454
    38Chevy454
    I like the idea. It should fit wiothout too many troubles, worse case is you have to fab up some exhaust headers custom, but a stock manifold could probably be found to fit with the steering box. The T-5 will give nice shifting and one more gear. Your stock bellhousing may have a different size bearing retainer size. Not sure what size you have if it is the larger truck size I presume? I think you can get a ring to fit the space.
    Being a divorced ransfer case, your concern is just the length. T-5 should hold up to 348 if you drive reasonable.
  13. cavman
    cavman
    My brother (since p***ed) once put a 348 with a BW 4 speed in his 57 Cameo, he really liked it. It fit well and worked well. He later tried a 427, and then a 6.5 turbo diesel.
    Let us know how it works for you. Them old Napco's are neat.
  14. chickenridgerods
    chickenridgerods
    from DSM, IA
    The W-engine was an option in the big trucks (grain trucks, dump trucks, COEs, etc); not available in the smaller trucks.
    A '65 date coded 348 would have been a replacement.
  15. donsz
    donsz
    Thanks, great info. I expect to re-build the 348 soon. I'll have to "noodle" the 3 speed OD vs. T5. I feel better about the swap now, it appears to be a reasonable project.
  16. tjet
    tjet
  17. jbo13
    jbo13
    The napco stuff is pretty rare I would keep if you can
  18. 40 & 61 Fords
    40 & 61 Fords
    Do you have an engine yet? I just went by the Kottkes' Bus Service garage (763-331-0590) in Andover on Friday, and they have an older bus for sale in the back lot that is marked as having a 348 if you are looking.
  19. bulletproof1
    bulletproof1
    from tulsa okla
    i have a 57 chevy bus with a 348...the motor mounts are home made ....someone needs it ...
  20. donsz
    donsz
    I do have the engine already, thanks though.
    don
  21. donsz
    donsz
    The engine is now just about ready, I intend to install it when it gets a little warmer here in Minnesota. I expect the header and steering box interference issue. I'm sure a few more things will emerge, but I think I will really like it when done. As usual, this was much more expensive than I thought, even though I did get an excellent deal on the machine shop work.
    don
    SERPENT likes this.
  22. Poh
    Poh
    from Quincy,Ca.
    Wellllll, if you decide you dont need that, It would sure look purty in my Sport Coupe!
  23. WOW, now I understand!
  24. Deuces
    Deuces
    That's a beautiful motor...:)
    How about a few more shots of the Napco???
    Thanks in advance...
  25. Twinpilot001
    Twinpilot001
    cant be a 348 in 65!!!!!!!!!!!!!! Keep the truck like it is!!
  26. squirrel
    348 was available in 60 and 80 series trucks in 1965.
    I think I would have done some mocking up to figure out the exhaust/steering solution before building the engine....but I expect you'll figure out something. Beautiful engine!
    I would not mess with the T5, it's a rather lame transmission for a *****in old 4x4. And you should be ok with the 3.90 gears and 4 speed if you have decent sized tires on the truck.
  27. JD Miller
    JD Miller
    The GMC 4x4 trucks 55 - 59 etc had Pontiac V8s in them
