Who can cast automotive lenses in glass?
Discussion in 'The Hokey Ass Message Board' started by SouthUrn, Mar 27, 2013.
  1. SouthUrn
    SouthUrn
    from US
    Need a couple small runs reproduced in gl*** from good lenses in hand. Resin/plastic is not an option. Heard there is someone in CA that can handle the task but searching hasn't turned contact up, nor has searching archives here. Any HAMBers capable or know someone that is? Thank you in advance.
  2. Send 40StudeDude a PM. His son is listed as an Alliance Vendor but last I checked his site was not working. Does some really amazing stuff with gl***.
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    They are are moulded. The melted gl*** is poured into the lower mould, usually the smooth outside and the inner mould (with refractor blocks, ribs, dots etc.) is then clamped down onto the lower mould. The temp and time spent in the mould determine the color of the lens. Clear first, yellow(amber) second and then orange and red, deeper red color the longer in the mould.
  4. Rusty O'Toole
    Rusty O'Toole
    I was surprised to find old bottles were made in wooden moulds. This tells me melted gl*** is not as hot as melted metal. It might be possible to make a mould out of wood, plastic or silicone. I don't know how it could be done, this is just a suggestion. Might be worth looking into.
  5. 28TUDOR
    28TUDOR
    I think molten gl*** is about 2500 degrees?
  6. nickleone
    nickleone
    Look for a small craft gl*** manufacturer or a local gl*** blower.
    Pressed gl*** plates are made in a 2 part mold. The bottom mold has the design and the upper is dished. The molten gl*** is placed on the bottom mold and the upper is pressed on top.
    Good luck
    Nick
  7. nickleone
    nickleone
  8. Barn Find
    Barn Find
    from Missouri
    This is good info. I need some new gl*** in a trafficator like this one.
  9. Flipper
    Flipper
    from Kentucky
    Gl*** has a wide range where it can be worked. Maybe it doesn't have to be heated to the point where it is liquid. I wonder if it could be just heated until "soft" and then pressed.
  10. You "work" it around 1600. The intial melting is done around 2500. Wood molds are used in blowing not sure about pouring though as I have only working in a gl*** blowing studio
  11. So what does the lens look like that you need to reproduce ? Can,t you find them anywhere , used or NOS. ?
  12. redo32
    redo32
    Randy Grubb out of Medford Oregon did art gl*** before becoming famous for the Blastolene specials. Just seen him on the Baileigh Tools site.
  13. 5window
    5window
    Technically, gl*** is always a liquid from a physics standpoint. Look at a really old sheet of window gl***, you'll find it is thicker at the bottom after year sof flow.
  14. 5window
    5window
    While I agree they are molded, your statement makes no sense regarding time in the mold equaling the color. Gl*** color is dicated by adding pigments,typically metallic salts. Red is usually a gold salt while amber is manganese or sulfur-Here's a link to color :http://chemistry.about.com/cs/inorganic/a/aa032503a.htm
  15. OHV DeLuxe
    OHV DeLuxe
    from Norway
    Actually the old windows were cut from big circular discs, the thick gl*** is where the gl*** were rolled out to and hardened. The centers of the discs can often be seen as small "bullets" or ****** shaped ornamental peices over the entrances on the same houses.
    How i know is that i was present when the regional antique authority visited a friends farm from the 1600s which is close to the oldest gl*** hut in the country and we thought the same thing based on folklore but were very quickly corrected. His facts made a whole lot more sense.. :) it takes much more time to deform by age.
    So our lenses are safe for a little more time.. Now back to cars.. :)
  16. TimW
    TimW
    from Kentucky
    Watching this with interest, I have some unique 32-34 Ford headlight lenses I'd like to have re-popped as well...
  17. SouthUrn
    SouthUrn
    from US
    Appreciate responses so far. Thanks fellas.
    One of the items needed is '59 Cadillac fog light lenses in different colors than standard clear. Colors from the factory exist, I have seen both broken and cracked originals in person (not Photoshopped images), but have not located any in over a year of actively searching. Additionally, having looked through every Cadillac master parts catalog from 1959-1967, can not even find matching parts numbers for them. Would like to have molds made from a set of clear originals.
    The other lens needed is a slightly larger oval. Similar application. With dwindling second hand supplies and steadily rising prices over the last decade reproductions are now worthwhile.
    I am familiar with hot shops having blown gl*** in college decades ago. Had thought about blowing into an exterior form before pressing inner form from opposite side. Then after kiln cooling, edge finishing and polishing in cold shop.
    Figured someone smarter than me had a better answer and HAMB resourcefulness was a great place to ask.
  18. manyolcars
    manyolcars
    You dont understand the definition of the word, 'unique'.
  19. Gerrys
    Gerrys
  20. SouthUrn
    SouthUrn
    from US
    No interest whatsoever in resin as initially stated.
  21. Fenders
    Fenders
  22. Blind Elwood
    Blind Elwood
    Thats not how gl*** sets it's color. Gl*** gets it's color from a combination of minerals added to the clear gl***. This was made with bule,black and gray then rolled in silver and gold leaf.
      43.1 KB
  23. Atwater Mike
    Atwater Mike
    Wow, Elwood...Wow...I enlarged the disc, then lookin it, and saw stuff from somewhere else, wow... That's far out. Dude.....
  24. 5window
    5window
    OK so one more diversion. Those old windows with the center bull's eye were really made by gathering clear gl*** on the end of a blow pipe and spinning the pipe so the gl*** whirled out as a disk. The think center is where the gather of gl*** attached to the pipe. Another way it was done was to blow a cylinder of gl*** and then cut in once lengthwise and flatten it out. Keep in mind as well that gl*** was much harder to work with and cut before the advent of carbide wheels for gl*** cutters-which don't really cut, but score the gl***, giving it a fracture line. If you want to cut gl***, you'll need a water jet-or a diamond/carbide bandsaw.
  25. TimW
    TimW
    from Kentucky
    While i fully understand the meaning, I happen to have more than one car that I'd like to run these lense's on and have only one set. But, thanks for your help!
  26. D.SCOTT
    D.SCOTT
    Well, I've been a gl***blower and gl*** worker for 20+ years, and its just not that easy to make lenses. I've done a few custom ones, but casting a copy of exactly what you want is gonna cost more than what anyone is going to want to pay, and its not going to be tempered or have any guarantee its going to hold up to all the vibrations and such. I get requests all the time, and wish I could find a cheaper way to do it!
  27. Tnomoldw
    Tnomoldw
    hahhh
  28. alchemy
    alchemy
    They used to GIVE AWAY pressed gl*** dishes during the depression at the local gas station. Detailed pattern clea and colored dishes, gl***es, cups, and bowls. So, if it was cheap enough and easy enough for some gasoline company to do it during the depression, there's got to be somebody still around who could do it for a reasonable price.
  29. gatz
    gatz
    gotta have quan***y !!
  30. Murocmaru
    Murocmaru
    from Van Nuys
    I think steve's auto restoration had some E&J lenses remade. They look great. You might try contacting them and see who they went through.
