Projects My Apache...
Discussion in 'The Hokey Ass Message Board' started by Shane Spencer, Sep 15, 2012.
  1. riley58
    riley58
    what an awsome job you are doing. i was going to rebuild the door hinges on my 58 today,only to find that 2 bols just keep spinning and can't get the door off. but after reading your build iam ready to go back out and work on it.
    KEEP UP THE GREAT WORK !!
  2. 1959apache
    1959apache
    I don't even have an e-brake setup :eek: I have all of the stuff for it though, don't know if I am going to go with it or not.
  3. tjet
    tjet
  4. 1959apache
    1959apache
  5. Shane Spencer
    Shane Spencer
    Thanks riley, im trying to get back to work, ive been slacking.
    Apache, my dad doesnt have a e brake on his jeep, he just leaves it in gear. If i was running an auto i probly wouldnt run one, but i may need one with a manual
    And tjet, ive thought about trying.to adapt a lokar unit to work with a custom bracket
    Sent from my DROID device using the TJJ mobile app
  6. Buzznut
    Buzznut
    There is really only one solution - you have to cut the heads off. The harder part, once you get the door hinges off, is that you have to refabricate a "cage" for the square threaded "nut" to float in so that you retain the ability to adjust the door alignment.
  7. tjet
    tjet
    I'm sure Lokar has one. I'm probably going to call them & get a auto shifter as well - I want to make sure they mount ok together. BTW, their stuff is expensive but top shelf.
    I'm also going to mount this shifter indicator light in my speedo head. It should fit above the OD if I take it apart
    http://www.lokar.com/product-pgs/shift-indicators/shift-indicators-pgs/ledboot-dash-ind.html
  8. tjet
    tjet
    You know, I thought that too when I needed to make room for my 455 Olds. Turned out that I really missed that e-brake. I moved to Manhattan Beach a couple years after I removed the ebrake - all hills!! I would always worry that the park pin would snap & I'd find my truck on the beach. It was also a ***** moving the shifter from park with a load on it
    http://www.palosverdeshomesandrealestate.com/wp-content/uploads/2011/10/Manhattan_Beach_houses.jpg
  9. Shane Spencer
    Shane Spencer
    Updates.... My stainless bolt kit came for the entireee truck. Im super stoked. I can slowly start getting the truck mocked up and then on to paint by late spring
    Also got my 6061 aluminum sheet to make the gauge panel, and my cratex sticks to engine turn it. I got the panel done with the gauges mounted, i holesawed the small gauges but had to drill a bunch of small holes and work the edge with a dremel on the bigger ones, i need to get a 6 pack of beer and sit down for the engine turning process. However long that may take....... :D
  10. sqrlnts
    sqrlnts
    Way to go Green baby! I love the **** out of your gauges! And by the way i solved the whole parking brake situation, now get on to the next problem!!! :D
  11. Shane Spencer
    Shane Spencer
    Thanks dude. ive actually known a couple people who carried chock blocks with em lol. Idk if its the best solution but hell, it works haha
  12. Shane Spencer
    Shane Spencer
    Got the panel turned.... Tedious **** lol
  13. Saxman
    Saxman
    Looks awesome, man. You're right though, that is a tedious job.
  14. Shane Spencer
    Shane Spencer
    Thanks, n Hell yea it is. I laid out a grid of sorts with a sharpie
  15. APACHE FS
    APACHE FS
    Well done, looks nice.
  16. n847
    n847
    That looks great, I'll be doing one for my Plymouth soon but it won't be quite that big.
  17. Shane Spencer
    Shane Spencer
    Thanks guys, im gonna get some amber indicator lights for signals and a small blue one for high beams. Still gotta drill the holes to mount it
  18. chaddilac
    chaddilac
    Whoa!!! dig the dash insert!!! Your running blinker and highbeam leds or anything?
    I found these....
  19. Shane Spencer
    Shane Spencer
    Thanks dude, Yeah im gonna run a small blue one for the highbeams, and two amber ones for the signal. Heres a few i found, they were on cl***icchev.com or something like that. The blue one is really small, signals are a little bigger than the blue one......
  20. 1959apache
    1959apache
    you need to countersink those turn signals, that would be really cool. That gauge cluster panel looks spectacular by the way. I know its a lot of work, it turned out great and matches the look you are going for in that cab too.
  21. Shane Spencer
    Shane Spencer
    Thanks dude, and Thats a killer idea with the signals, ill definately test it out and see how it looks. I think the panel will look good against the black dash. Should pop pretty well. Also its hard to see in the pics, but theres two small strips where the cratex sticks left a residue in the engine turning. Its darker appearing in the right light, ill have to figure a way to remove that
  22. chaddilac
    chaddilac
    That yellow one you posted is larger than you think. I bought several of those and they were large!!! Almost 1/2" I think. Those I posted are like 1/4".
  23. TaylorCrawford
    TaylorCrawford
    You dont need a parkin brake, you just need a parkin brick!
  24. Shane Spencer
    Shane Spencer
    Chad you wouldnt happen to have any pics of one of them installed would you ? The gmc dashes have big signals stock, so i dont think they would look bad. Heres a pic of the stock size ..... There the little gauge looking things under the speedo and tach
  25. Shane Spencer
    Shane Spencer
    Btw guys, you think i should stick with the impala wheel or go with the stock wheel i picked up a few days back. I still like the impala, but the stocker is growin on me.....
  26. MEDDLER1
    MEDDLER1
    Yeah man that panel looks awesome! I vote for the Impala wheel since yer askin!
  27. APACHE FS
    APACHE FS
    Impala wheel would add a little flash, in my buddy's truck we are considering remounting the stock brake lever in a vertical position near the vent on the left side. His will be auto so it's just an inspection technicality.
  28. chaddilac
    chaddilac
    No I sure don't.... I can get you a pic if you need one?
  29. Red Ryder
    Red Ryder
    Green, that might have been some tedious ****, but what a fabulous finished product! I am impressed!
  30. Shane Spencer
    Shane Spencer
    Thanks fellas, and dont worry about it chad. Just curious if you had a pic on hand. Do you have any of those indicators left over ?
