Transmission ?????
Discussion in 'The Hokey Ass Message Board' started by jumbogem29, Mar 25, 2013.
  1. jumbogem29
    jumbogem29
    from Alabama
    What is a 4L60E GM transmission is it a good one or do i need to stay with a 350 turbo. I bought a 350/290 hp crate motor is this a good choice for this motor build is a 30 sedan. Thanks
  2. Boxcar's 1928
    Boxcar's 1928
    I believe a mod "may" be killing your thread....I know there was a few replies a minute ago. Only the Shadow knows!
  3. 1934coupe
    1934coupe
    As far as I know the 4L60 is a computer programed trans. If your not running a TPI or computer there is no need to run a 4L60. 350 TH done up are just fine.
    Pat
  4. Jay Tyrrell
    Jay Tyrrell
    I would personally stick with a 700 R4 or a 200 R. I think that you need the cars computer that the transmission came out of for the 4L60E to work properly.
    Jay
  5. jumbogem29
    jumbogem29
    from Alabama
  6. nali
    nali
    The trans only needs the throttle boby sensor connected. Easy to adapt on any carb.
    I swapped an OT from TBI to carb and just had to build a support for the TPS
  7. MAD MIKE
    MAD MIKE
    from 94577
    The 4L60E is the electronic version of the 4L60, which was just the TH 700 R4 renamed.
  8. CutawayAl
    CutawayAl
    from MI
    I posted what I thought was a helpful response. Along with a number of others it is gone. Apparently electronically controlled transmissions are off limits, the forum is misbehaving, or someone just needed to delete something.
  9. fiftyv8
    fiftyv8
    from CO & WA
    As stated the ****** you are talking about is an electronic over drive item.
    Where as the T350 is does not have an over drive gear.
    So if you are not running electronics and want an over drive ****** the T700R4 is probably your best bet and it will be cheaper and easier to install as you want need to worry about getting the electronics setup by some guy who will probably charge too much for very little.
  10. nali
    nali
    If he already has the trans, the adaptation is really easy and doesn t cost anything but a few wires and a bracket to fix the sensor.
    Here s what I did, no rocket science.
  11. hotroddon
    hotroddon
    If you want an Overdrive at your power level I would go with a 200-4R. It is smaller than the 700, in fact a petty much direct replacement for the TH350. non computer controlled and can be built to handle up to 1,000 HP. But a well built standard version will easily handle your 290Hp 350
  12. Gman0046
    Gman0046
    hotroddon x2. A 200R is the way to go.
