F100 dropped axle
Discussion in 'The Hokey Ass Message Board' started by txlonghorn, Mar 29, 2013.
  1. txlonghorn
    txlonghorn
    Curious as to what type of dropped axle you guys would use for a 53-56 F100. I'm looking at the tube dropped axle similar to the one sold by Mid-Fifty or an original stretch from Sid's dropped axle.
  2. aircoup
    aircoup
    if i was gonna use one , itd be the one from sids, , is mordrop still in business ?thats what we used to use before i started installing volaries ,, anyway enjoy it and have fun with that effie
  3. txlonghorn
    txlonghorn
    Looking to keep it old school. From everything that I've read Mordrop closed.
  4. tjet
    tjet
    I got mine from Sid's
    A+ in my book
  5. conormulroney
    conormulroney
    I have an old Mordrop on my truck. I do believe they are out of business for many years, now.
    Go with Sid's. I'd rather have an original dropped Ford axle than an aftermarket tube version.
  6. Carbs & Chrome
    Carbs & Chrome
    Original dropped w/ stock springs:
  7. txlonghorn
    txlonghorn
    How're you guys setting up the front suspension with the dropped axle? I'm thinking of using Sid's 3" dropped axle with stock springs since I'm wanting to use this as a daily driver. Could I go a little lower without sacrificing ride quality? What'd you do to prevent bump steer? In the rear I've installed a Ford 9" with a set of Posie 3" lowering springs.
  8. tjet
    tjet
    If you click on the link below, you will find some pics when I installed mine. I went with a 4". Cant tell you about how it steers yet, still building the motor. I netted around a 5" drop with one leaf removed from each side
  9. Sprout
    Sprout
  10. Sid's does a fine job. I like tube axles well enough but you can't beat a dropped original axle. Sids is where I would be headed if I was getting one done.
  11. wreckfixer
    wreckfixer
    SIDS dropped axle on mine and a leaf or two removed. ImageUploadedByH.A.M.B.1430509801.252463.jpg
    Sprout likes this.
  12. HammerDown
    HammerDown
    Sid's for sure...
  13. That is one fine truck sits about perfect.
  14. seb fontana
    seb fontana
    from ct
    Sid's would be my choice....The after market tube axles from Mid-Fifty is ok if the quality is there; meaning the king pin bore must be tight and the lock bolt hole the right size and in the right location or you will have heartache...Speedway used to carry them [don't know if same manufacturer as Mid-Fifty] and I bought one in the garage sale and all the holes are junk, won't be able to use with out machine work especially to lock bolt holes...If your axle is good [hole wise] then I would call Sid's and see what the turn around time would be if you sent him yours to drop.....
  15. willymakeit
    willymakeit
    Sid does a good job. Im running a 57 axle [1 to 1 1/2'' drop] with reversed eyes and down/forward springs in front. Extended y hangers ,flipped and relocated hangers plus reversed eyes in rear.
