POS or NEG Battery Disconnect switch
Discussion in 'The Hokey Ass Message Board' started by The37Kid, Mar 28, 2013.
  1. Positive Side
    131 vote(s)
    52.6%
  2. Negative Side
    118 vote(s)
    47.4%
  1. child9
    child9
    from Austin
  2. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
    I imagine as a "battery disconnect" either side of the battery will do, but the "normal" method I have been exposed to is to switch the +pos side of the battery.
    Now as a "kill switch" that has only been touched on here this is what I would recommend to prevent the back feeding as stated earlier through the alternator.
  3. Carter
    Carter
    Shoestring, Kerry, Anderegg, this is the argument that makes sense from a vehicle electrical shut off point of view. The alternator does act like a battery, and, as stated, if the ground circuit uses the ch***is and engine, the alternator ground can't really be switched.
    Kerry, a lot of the electron talk, while it doesn't necessarily matter in this conversation, was just being brought up to dispute those who were saying that the electricity flowed from positive to negative and that the positive is the 'feed' side.
    Sent from my DROID device using the TJJ mobile app
  4. Carter
    Carter
    Also, the positive ground comment was not 'trolling'. My car is 6V positive ground.
    Now, Kerry, a question for you. With the requirement that the battery isolator be up front, from a safety point of view, it would seem to me that the battery would be better off up there as well. Is there a rule requiring the battery to be in the rear, or is it a matter of weight or lack of room up front?
  5. child9
    child9
    from Austin
    Awesome. This is why I'm here...to learn something. The positive ground setup is interesting. Are there any devices in the car that are polarity sensitive and require this per the original design? I can't think of anything that would be...unless a generator or ammeter of some type was. What year is the car? I would guess it is late 19 teens to twenties. Thanks!
  6. Carter
    Carter
    It's a 1929 Ford. Most cars were positive ground into the late 1940's, and some British cars until the 60's. Boats may have gone even longer.
  7. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    As far as I know, GM went from 6 V pos ground to 12 V neg ground in '55. Ford and Chrysler in '56.
  8. subieseven
    subieseven
    from New York
    so Bob- which side do you vote for?
  9. tb33anda3rd
    tb33anda3rd
    after this thread; he decided to use hand signals, carbon gas lights, hand crank and a magneto.
  10. Kerrynzl
    Kerrynzl
    The isolator is best placed as close to the battery as possible. Any wiring between the battery and the isolator is exposed to a dead short [in an accident situation ]
    Motorsport NZ [an affiliation of the FIA] requires the isolator to be at the base of the windshield on the cowl or the fender with a blue triangle and a lightning bolt decal .
    The tech inspector would occasionally walk along the "Dummy Grid" and flick off all the isolator switches ,and any car still running wasn't allowed on the track.
    Now because we are all seeking the elusive 50/50 weight distribution, it is common practice to put the battery in the trunk.
    That is why I used a solenoid on the main starter feed , and the wire to the isolator switch has a fusible link [at the battery post]
  11. The37Kid
    The37Kid
    ^^^^^^^^^^^^^^Keerynzl, WHY are there arrows on the LEFT and RIGHT of the OFF notice? I sure would like to have things clearly marked so the fire could stop quickly. Bob
  12. Kerrynzl
    Kerrynzl
    That is a picture I plagiarised off the 'net, from a vendor selling them.
    We would buy a universal decal kit for motorsport cars, what we had to do was trim off the arrows so it showed "OFF" only
    Kerry
  13. The37Kid
    The37Kid
    THANKS! Bob :)
  14. ct1932ford
    ct1932ford
    I'll Bet He Does Both:eek:
