t5 transmission input shaft 1954 chevy Help!
Discussion in 'The Hokey Ass Message Board' started by elrodeo13, Apr 3, 2013.
  1. elrodeo13
    elrodeo13
    I am trying to put a 1991 s10 manual transmission in my 1954 chevy 235 inline six. the problem is the old input shaft has 10 teeth on the spline and the new ****** has 14. I ***ume I have to change it out. Can I switch out the old one or do I have to get a new input shaft, and where can I get one. I looked at the posts on here and could not find the answer. Hope someone can help.
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    You get a new clutch disk with the correct splines. You don't mess with the trans at all.
  3. judd55
    judd55
    from B.C.
    ^^^^ What he said, just look up a clutch disc for a 91 S-10 and you are good to go. ;)
  4. gimpyshotrods
    gimpyshotrods
    Yup. That's it. See, way easier than going inside the transmission.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    But instead, he has to get into the Bell housing ;)
  6. gimpyshotrods
    gimpyshotrods
    MUCH less scary in there.:eek:
  7. Hnstray
    Hnstray
    from Quincy, IL
    I do not see any mention made in the OP's post about an adapter plate. As I recall, this transmission will not directly bolt up to the original bellhousing for two reasons, 1) the bolt pattern is different and 2) the input shaft is too long as is.
    The adapter plate addresses both these issues at the same time.
    Ray
  8. ventureboy
    ventureboy
    Go for a heavier clutch disc from a small block Chevy. After changing 2 of them on my 91 S10 4X4 years ago, I found that the V8 disc fit and lasted better.
  9. gimpyshotrods
    gimpyshotrods
    Good point. I just ***umed that he had one already.
    If not: http://jalopyjournal.com/forum/showthread.php?t=787178&highlight=t5+adapter
  10. brokenspoke
    brokenspoke
    T-5 tech try searching it....all the info you need
  11. I just did that swap in my 54. The adapter is a must. I went to a clutch and drive line shop and had them make up a new clutch disc with the proper spline and pressure plate. Works like a charm.
    Later,
  12. elrodeo13
    elrodeo13
    Thanks for the info!!!
  13. elrodeo13
    elrodeo13
    Got the Adapter plate, just waiting on the mail
  14. elrodeo13
    elrodeo13
    Got the transmission mounted, clutch and pressure plate installed. Has anyone had any issues with adjusting the clutch? I am out of threads on the linkage offset rod.
    Was wondering if I should shorten the linkage or lengthen the rod?
    any suggestions?
  15. brokenspoke
    brokenspoke
    which throwout bearing did you use?
  16. elrodeo13
    elrodeo13
    stock s10 TO bearing from a 1991 s10 t5. I am gonna take some measurements tomorrow and I will post them. I have a feeling the pressure plate I ordered from national chevy ***. is the wrong one. They said it was a stock 54 chevy pressure plate but I am having my doubts.
  17. 24riverview
    24riverview
    If you can trust the pictures on Advance Auto's site you've got the wrong throwout bearing. It shows the S10 as using the short bearing where the 54 needs the long version which would explain running out of threads on the adjustment.
