500 Caddy in 50 Plymouth sd coupe
Discussion in 'The Hokey Ass Message Board' started by swaluda, Apr 4, 2013.
  1. swaluda
    swaluda
    from pa.
    Gonna do it. If you guys would have any usefull tips on positioning this engine i would appreciate it. Trying not to cut the firewall if i can help it. Biggest concern is drivers side exhaust manifold possibly whacking the steering box. What would my exhaust manifold options be? Ideas on engine and trans mounts needed also. I know it can be done, so dont be bashfull, lets geter done. Need you Hot Rod boys to put some skill together here and help out this Good ole boy. I got the tools, just lackin in how ta. Stan
  2. Good luck gettin that big pig in there. that is a small compartment to be trying to put that in and you are going to be hard pressed to get enough radiator in there to keep it cool.. i do not think you will find a manifold to fit by the steering so plan on making some sort of headers.
  3. blue68deville
    blue68deville
    Sounds *****in! Sanderson makes headers, maybe eldorado manifolds would clear??
    Check out MTS for any engine help, they're top notch and won't try to sell you a bunch of **** you don't need.
    Cadillac power forum guys may have some ideas for exhaust too
  4. swaluda
    swaluda
    from pa.
    where do i find MTS?
  5. blue68deville
    blue68deville
  6. HOTRODPRIMER
    HOTRODPRIMER
    Really,back in the late 60's we stuffed a 500 CI caddy in a 62 Rambler,,,it will fit! HRP
  7. plymouth1952
    plymouth1952
    a few things remember the motor sets an inch to the drivers side. as the manifolds tuck like an olds i think if you keep the motor high in the bay you will be ok. the area i see as an issue will be the trans tunnel rework the bell houseing area and it should fit. the side well on the p*** sde is a two peace well and can be cut down i did on mine. the drivers side should be ok. you may want to set the steering box into the frame more for room in that area, use a Borgason at the box and firewall. post shots want to see this one. bob
