lets see your custom Model A dash pics
Discussion in 'The Hokey Ass Message Board' started by Zob Rombie, Jan 19, 2008.
  1. Zob Rombie
    Zob Rombie
    from Chicago
    getting to the point of interior work here at the shop...throwing around ideas on how to do my dash. Lets see what you guys have done. mind you im not talking about a stock A dash with the original 4 gauges...i want to see diamond plate, louvers, custom clusters, custom glove boxes...whateveer you got, as long as its creative.
    post em' up hambers
  2. Ratty55
    Ratty55
    from Frohna,MO
    Here's the start of mine, 34 chevy dash grafted to the original 28-29 top.
    Ratty55
  3. Sour Kraut
    Sour Kraut
    Customers Brookville '29 r.p.u with '32 dash and S.W. gauges.
  4. Slag Kustom
    Slag Kustom
    57 ford dash cut down to fit with sw gauges mounted from behind. switch knobs from scratch, 64 corvette radio, polished stainless ac vents, garnish molding from scratch flowing into a water fall console between the seats. cut down 56 caddy wheel, custom column with self cancling turn signals. the list goes on and on about 200 hours so far.
    deathrowdave and kiwijeff like this.
  5. heres mine...32 Desoto..narrowed 1/8 " on each side, redrilled the upper holes into the model a crossrail and put nutzerts there for the machine screws to go into. (not using the banjo wheel...got a deep dish 66 olds toronado..works for me real well. :)
    kiwijeff likes this.
  6. Dyce
    Dyce
    Still in the building stages. I used a 1940 Chevy dash. Sorry I don't have the guages and chrome on yet.
  7. HELLMET
    HELLMET
    32 dash nickel plated and engine turned.
    hfh and kiwijeff like this.
  8. rustydeuce
    rustydeuce
    My Coupster dash.
  9. Hanky
    Hanky
    from Sweden
    Here is mine a shortened Buick -51 dash. It is black but on this pic it look gray because of all the dust. The car is a -31 model a truck that hopefully gets drivable in the spring.
  10. michael037
    michael037
    Sour Kraut, do you have any more shots of this car?
    Thanks
    Michael
  11. Heres my 36 Ford dash with 52 olds gauge pod. [​IMG][​IMG][​IMG][​IMG]
    30tudor and kiwijeff like this.
  12. dezaster
    dezaster
    from u.k.
    rhd '60 impala, narrowed about 2 feet, and peaked in the middle-
  13. LeadSledMerc
    LeadSledMerc
    Basically 47 Merc sliced and diced...
  14. Noland
    Noland
    heres my dash, a 53 ford truck, pretty simple
  15. 383 240z
    383 240z
    Here are some from a '28 truck I'm building for a customer. I'm not sure if this dash will make in into the final product, but I'm kinda liking it. It started out as a '41 ford dash. And before yall start yelling I didn't pick the wheel, column or the steer clear unit. This is a customer cars not mine!! the glove box is shortened about one inch and the majority was sectioned from the center. The ashtray is still stock size but welded shut to be used as a mount for the HVAC controls. Keith
  16. elcornus
    elcornus
    This is the gauge cluster from a 28 studebaker,
    it will be installed into a '32 style dash made to fit model A's, with rebuilt gauges , or SW's.
  17. hotcargo
    hotcargo
    just a thought for you model A closed car guy's , a '34 closed car dash is almost a bolt in , I just made a couple of tabs welded to the door pillars and its in , top curveture is perfect to mate to the screen , people ask me , must have taken a bunch of work to get that in there.......nuh .........here's an old pic I've just scanned........
    src="http://i59.photobucket.com/albums/g308/hotcargo/34dashinAClosedCab002.jpg"
  18. Just Gary
    Just Gary
    pat59 likes this.
  19. Zob Rombie
    Zob Rombie
    from Chicago
    cool guys, alot og good ideas out there, on even better projects. once i get a little more done on mine ill post up some pics from before to current. Thanks again...and why not, lets keep 'em coming!
    -Zob
  20. b-bop
    b-bop
    Looks like this thread died a while ago, but I got a couple pics to add..........
  21. Back from the dead for more cool ****! Please
  22. Fenders
    Fenders
    THAT is the most creative thing I've seen !! Nice work.
  23. HotRodHoon
    HotRodHoon
    34 Buick meets model A...
  24. snopeks garage
    snopeks garage
    from macomb MI
    i love it! cool idea
  25. Jakesrocks
    Jakesrocks
    Using the stock tank with 32 dash & machine turned insert. It gives just enough clearance for the gauges.
    I don't have a pic, but a custom sending unit has been mounted in the bottom of the stock tank for the electric fuel gauge. Stock fuel gauge is used minus the float and arm, to prevent fuel leaking from that area of the tank.
  26. pecdaddy
    pecdaddy
    Here's mine
  27. Chucky
    Chucky
    Using stock tank and fuel gauge.
    kiwijeff and 1927graham like this.
  28. mad mikey
    mad mikey
    Just Gary, kiwijeff and 1927graham like this.
  29. GordonC
    GordonC
    Heres mine in a 1931 roadster… been done a lot but still cl***ic.
  30. Finished this build in August, 2014.
