broken gas tank line fitting help
Discussion in 'The Hokey Ass Message Board' started by peter schmidt, Apr 6, 2013.
  1. peter schmidt
    peter schmidt
    from maryland
    Dropped the tank on the hudson yesterday thought it was empty but turns out the rubber they used to isolate it from the underside of the trunk floor was just stuck to it so of course it dropped when i wasent ready and spilled some nasty stale gas all over ne and broke the feed line off at the weld into the tank. my problem is i dont know how to fix this without welding it and im not real comfortable doing that.any sugestions? The tank is not factory but its a well built home made job but id hate to have to buy a ned one over just that line
  2. HOTRODPRIMER
    HOTRODPRIMER
    Take it to your local radiator shop,,most of them have huge vat tanks and it would be wise to let them dip it overnight in the hot tank to desolve and remove any sludge,,let them repair the fitting while the tank is in the shop. HRP
  3. Partsman2012
    Partsman2012
    The only fuel tank I've had to patch was done at a radiator shop.
  4. peter schmidt
    peter schmidt
    from maryland
    Ok ill start looking for a radiator shop and get sone pics
  5. Almost a guarantee that it's soldered.
    Cosmo
  6. 37 caddy
    37 caddy
    from PEI Canada
    Also look for a sheetmetal shop,they use solder to make some of their vents and stuff,some of the guys who work there are pretty good at soldering,since they use a hot stick,no flame,the tank doesnt have to be so clean,i had one of mine done at a local shop that way. Harvey
  7. jkeesey
    jkeesey
    I dont know where you are in Maryland but i use ****s Radiator up here and they do a fantastic job. It will most likely not be a 100% fix but you could also use a permatex gas tank repair kit.
  8. Rusty O'Toole
    Rusty O'Toole
    What is the tank made of? What kind of shape is it in? If it is plain steel and/or rusty might as well go shopping for a new one.
  9. peter schmidt
    peter schmidt
    from maryland
    Its not soldered its a home built sheetmetal tank its clean as ive ever seen inside. it held up pretty well broke just after the weld i went and bought some gas tank sealant stuff and a double barb br*** fitting lathered it up with the seal all and drove it in with a hamner its 1/4 inch inside diameter so hopefully that will be enough. i think it will work but time will tell i guess ive used the seal all stuff before and it saved my *** when i backed into crooked parking block at work and it ripped the drain plug out of the tank on my mustang hopefully it can save my *** again. heres some pics i decided to go this route because it was cheap and this tank is a little big so i may switch to a smaller less tall tank in the future anyway for ground clearance.
  10. panheadguy
    panheadguy
    from S.E. WI
    Good luck withat ****
  11. HOTRODPRIMER
    HOTRODPRIMER
    I am going to agree,,it's like putting a band aid on a bullet hole. HRP
  12. 51hornetdude
    51hornetdude
    from denver
    It may seem like an obvious question, but have you tried to find a Hudson gas tank?
  13. JohnEvans
    JohnEvans
    from Phoenix AZ
    That joint needs to be 100% air tight now and as long as you use it. ANY tiny little air leak and your fuel pump will not pump fuel.
  14. If that fitting is on the bottom of the tank, you'll know pretty soon whether she'll hold.
    Cosmo
  15. peter schmidt
    peter schmidt
    from maryland
    No theres a metal tube that runs down to the bottom of the tank that they left sticking out to use as the fuel outlet thats what broke i think it will be a tight enough fit i used the sealer and i had to smack it pretty good to get it all the way in and like i said its only gona be temperary until i get a new tank the cars not even on the rd yet i cant drop 2 or 300 on a new tank i have other financial priorities if it works it works if not im only out 6 bucks
  16. 296 V8
    296 V8
    from Nor~Cal
    Did you try a NPT tap in that hole?
  17. Don's Hot Rods
    Don's Hot Rods
    from florida
    That is the scariest repair I have seen in a while. You realize that you are dealing with gasoline here, don't you ? Stop screwing around and take it to a radiator shop as the guys suggested and have a proper/safe repair done.
    Don
  18. jkeesey
    jkeesey
    Hit up carlisle in a few weeks and you can get a new tank for around $20
  19. Muttley
    Muttley
    Looks like an OlSkoooooolRodzzzzzz tech article.
  20. Cruiser
    Cruiser
    Very poor repair, it's gas your dealing with here, you shouldn't do Mickey Mouse repairs. Like the guys say, take to a shop for repair or better yet get a new tank. :(
    CRUISER :cool:
  21. Don's Hot Rods
    Don's Hot Rods
    from florida
    Even if it weren't broken that tank doesn't look real swift. Kinda cobbled up from the picture. Do yourself a favor and spend a few bucks to get either a replacement and have it boiled or buy an aftermarket tank.
    Most of us are on budgets but there are times when spending a few bucks just has to happen to make things right. Steering, brakes, and fuel systems are places where you do not want to skimp.
    Don
  22. peter schmidt
    peter schmidt
    from maryland
    Allright u guys got me convinced i wont bother putting it back in wasent gona run it on the street anyway . Just wanted to get the car running and work the bugs out. Guess ill start saving fir a new tank
  23. tommy
    tommy
    I'd wire bush the **** out of it and solder that barbed fitting into place. I'm cheap and repairing is more my style than just replacing everything. I don't believe in the throw away economy. Probably not a job for a novice but not an insurmountable obstacle either.
  24. flynbrian48
    flynbrian48
    The inside of the tank has to be as ****py looking as the outside. If you're doing this on the cheap, spend some time scrounging in a wrecking yard and find a tank that'll fit the space. A nice clean poly tank from a late 80's thru early GM full size car would be my first thought, that's what is under my 48 Pontiac.
    If you're just trying to get it running, use a boat tank, not that rusty mess you have.
    Brian
  25. peter schmidt
    peter schmidt
    from maryland
    Thats the thing this tank is spotless on the inside but oh well it would have been a little to tall anyway since im going to lower the car. i may try to find a mustang or falcon tank to use since there pretty flat i cant seem to find a company that makes a replacement tank and im sure there pricy.
  26. FlynBrian
    FlynBrian
    65 to 68 Mustang tank new with drainplug under a $100.00
    http://www.cjponyparts.com/fuel-tank-with-drain-plug-1965-1968/p/FT2/
    Don't know where in Maryland you are, but they may be close enough to you that you could drive and pick up, looks like free shipping on it anyhow,
    Brian
  27. Don's Hot Rods
    Don's Hot Rods
    from florida
    If you do decide to do any torch work on it remember that the fumes are more explosive than the gasoline itself. :eek: Any remnants of gas fumes have to be scrubbed and scrubbed out before any ignition source is put near one.
    Don
  28. 296 V8
    296 V8
    from Nor~Cal
    Purge the oxygen from the tank with argon and silver solder that br*** hose connector in …. your done
  29. B Ramsey
    B Ramsey
    clean up area, fill tank with water, weld on threaded fitting, done. simple. easy. not a whole lot to discuss.
