Grant Spalding Distributor ID
Discussion in 'The Hokey Ass Message Board' started by snot275, Apr 7, 2013.
  1. snot275
    snot275
    Got this distributor from a buddy of mine and am trying to do an ID on it. It appears to be engraved with "G S", so I'm ***uming Grant Spalding (although the G looks like a C). Early? Later? It's a 2 bolt as well. Thanks guys!
  2. alchemy
    alchemy
    I don't recognize the two weird hooks cast in the sides, but the rest looks just like a regular old '42-'48 distributor. The CS looks cast in, not stamped later.
  3. titus
    titus
    And i believe grant bought out spalding so they either say grant or spalding but not both.
  4. snot275
    snot275
    Which makes this whole thing completely confusing to me... I'm honestly lost on this one, haha...
  5. Dale Fairfax
    Dale Fairfax
    Post this over on the Ford Barn but leave out the "Grant-Spalding" reference. Merely refer to the two wierd hooks.
  6. Bruce Lancaster
    Bruce Lancaster
    It's just a slightly odd casting...distributor is otherwise normal '42-WWII distributor.
    I've never seen those projections either, but I have seen a lot of variations in those castings. Points, etc. appear to be stock Ford.
  7. Bruce Lancaster
    Bruce Lancaster
    Could we have some pics showing those odd lumps?? Need some fuel for speculation here!
  8. snot275
    snot275
    As soon as I get home from work! Thanks guys!
  9. 40Standard
    40Standard
    from Indy
    ask Ron at the barn, he really knows his distributors
  10. snot275
    snot275
    Here ya go!
  11. alchemy
    alchemy
    Those lugs on the sides look like they could have clamps hooked on to them. It's probably a Ford HP optioned distributor with mounts for rev limiter straps that hook down to the frame. Very rare.
  12. snot275
    snot275
    have you ever seen one, personally?
  13. Bruce Lancaster
    Bruce Lancaster
    CS is cast in so it's original. I can't think of a match to that in known distributor suppliers that supplemented Ford over the early years, like Standard, Autolite, Mallory...it may well mark a foundry source for the aluminum casting or even one of the small Ford satellite plants.
    The distributors I have tend to have cast in letters on the back, presumably supply chain marks of some sort, and stamped letters on the rear of the flange which could mark rebuilders or maybe just inspectors. Not meaningful, though, just a mark on an original Ford casting.
  14. snot275
    snot275
    OK, so I think the end state is that this is just a regular 'ol stock distributor. Thanks a lot guys for clearing all that up!
  15. Bruce Lancaster
    Bruce Lancaster
    It is a regular stock Ford distributor with weird appurtenances...that are yet to be accounted for! It's not a speed equipment part, though.
  16. Bruce Lancaster
    Bruce Lancaster
  17. GMC BUBBA
    GMC BUBBA
    Another stock two bolt crab, i have a few of these in my core collection. Beats me as to why the tabs were made that way????
  18. Bruce Lancaster
    Bruce Lancaster
    One thought...it might have been an early way to locate and hold the thing as it was machined. This stuff had to be carefully located so normal Ford timing procedures would work. Not like a rotatable distributor with both body and shaft movable.
  19. chickenridgerods
    chickenridgerods
    from DSM, IA
    The Grant buy-out was way after the Flathead era, too. The OHV engines had taken over by then.
  20. pasadenahotrod
    pasadenahotrod
    from Texas
    It may a military modification for waterproof ignition shielding for trucks and other military Ford V8 powered stuff.
  21. snot275
    snot275
    These are some really good thoughts guys! Keep 'em coming if you think of anything else!
