Projects 26 roadster build; Bang Bang
Discussion in 'Traditional Hot Rods' started by h.i., Nov 4, 2012.
  1. falcongeorge
    falcongeorge
    from BC
  2. Totally *****en build!
    But... your wishbones are upside down.
    Sam
  3. Tnomoldw
    Tnomoldw
    :)No headlite mounts yet? Here got to love these ,;):cool::D
    -Brent- likes this.
  4. Atwater Mike
    Atwater Mike
    The use of the '48 Ford front crossmember in the center was excellent.
    But the A-D brackets (the mental picture arriving at the finished FORGING ala Miller Race Cars)
    Truly inspiring.
    The shell sectioning was perfect.
  5. h.i.
    h.i.
    from denver
    Afternoon ladies! Thanks for all the compliments, I needed some inspiration today. Thanks Sam, I know about the wishbones. I figured I was going to need every little bit for tie rod clearance, but after we pie cut them for the final install, it turned out to be a wash.
    I have done 3 sets of headlight mounts so far, and they were all ****. I would highly recommend placing headlight first, then shocks, haha.
    And thank you Mike, that is high praise coming from someone like you. As cool as those mounts are, I am concerned about the strength. Still on the fence about those.
    Home sick today, I'll get some pics up a little later. Cheers!
  6. I'm CRAZY about this car!! What a cool build.
  7. h.i.
    h.i.
    from denver
    Thanks Paul. Hopefully you get to see it at some point. Here are some updates. The first version of the ****y headlight stand, too far apart:
    Version 2: Moved the shocks outside and did a separate stand, these are probably final with a little adjustment:
    kidcampbell71 likes this.
  8. h.i.
    h.i.
    from denver
    This radiator is so cool it deserves it's own thread. I can't recommend this guy enough. Carl at Spike Radiator in Englewood, CO. This was just over half what a walker costs, built EXACTLY to my specs with my tanks and a new core. 5 FREAKING ROWS, I probably don't even need a fan, haha. Anyway, give this guy some business if you're local.
    That's it for tonight. I have to put the front of the motor together and figure out the fan so I can mount radiator, shell and everything else. Hopefully this week.
    OFT, kidcampbell71 and -Brent- like this.
  9. Six Ball
    Six Ball
    from Nevada
    Great radiator, you'll have the coolest car ever! Where do you put the water in?
  10. h.i.
    h.i.
    from denver
    It's a closed system like the new diesels. Fill it once and it's good forever.
    brEad likes this.
  11. Six Ball
    Six Ball
    from Nevada
    Well that will work then because flatheads are forever. That is longer than "until death do us part."
  12. SOHC427
    SOHC427
    Carl did the gas tank work for my 64, and fuel tube increase. Great rads, and gas tank work!!
    Eric
  13. GARY?
    GARY?
    Looks like nice work. The lack of a radiator cap is tripping me out.
  14. Olderchild
    Olderchild
    from Ohio
    May be a woopsie did i do that?
  15. h.i.
    h.i.
    from denver
    Just kidding. I had the option of waiting to install the filler and paint it till later. I don't know where it will end up yet. Found out I need to adjust the feet. Also I forgot to tell him to flip the lower outlets so they point down for a better angle. oops. Working on a new pitman arm tonight. I will try to get some pics.
  16. Six Ball
    Six Ball
    from Nevada
    Sometimes good planning is knowing when not to over plan. When we were building my son's Stude we took the radiator back so many times the guy started hiding from us.:D
  17. lakeroadster
    lakeroadster
    from *
    Thanks for the tip :cool:
  18. h.i.
    h.i.
    from denver
    OK, got another small update. Running in to multiple issues with the front wishbones and pitman arm so I need to figure some stuff out.
    Built a pitman arm to correct for the 45* issue with the F1 box:
    Still needs a new ball and some bending to clear the wishbone, but that's another issue
  19. h.i.
    h.i.
    from denver
    Finally finished the shock mounts and the headlight stands. Maybe add a spreader bar later. Grill shell and radiator are also mounted.
    OFT likes this.
  20. thunderbirdesq
    thunderbirdesq
    Cool as can be!
    I just file out the 4 locating splines in those pitman arms and clock them as needed.
  21. lorodz
    lorodz
    Looks good
    Sent from my DROID device using the TJJ mobile app
  22. Bugsy
    Bugsy
    from Kansas
    Just came across this thread....very cool car and great work! Can't wait to see more!!!
  23. PINEAPPLE
    PINEAPPLE
    Thanks for that, we wondering if that would work. That will save a bunch of work and pitman arms in the future!
  24. PINEAPPLE
    PINEAPPLE
    That last post was a response to thunderbirdesq, sorry, not the best forum operator:D:D
  25. ESGEE
    ESGEE
    from Sweden
    Like the look, but whats up with the windshieldframe?
  26. 26 roadster
    26 roadster
    that is stock, very seldom seen in captivity.........................lol
  27. Shaun1162
    Shaun1162
    Dang, nice lookin roadster! Always loved the look the of the turtledeck and the rear half of the body. Good work on the taillights and the license plate light (nice find btw!), nice clean look
  28. HotRodMicky
    HotRodMicky
    Yeah, much easier
  29. ESGEE
    ESGEE
    from Sweden
    Hahaha...
  30. laydout36
    laydout36
    from Texas
    awesome looking build
