AV8 Rear End Question-
Discussion in 'The Hokey Ass Message Board' started by chris98006, Apr 8, 2013.
  1. chris98006
    chris98006
    from Seattle WA
    Hello All,
    I have a 30 coupe and I'm close to completing a AV8 swap with a 50 8BA, 39 Trans, F1 cross Member, etc. I have a 40 Banjo for the rear end and it's about 1 inch wider than the stock Model A rear end. Can I run the Model A rear end? I'm sticking with the torque tube, and it looks like everything will mount up good. Can the Model A rear support the extra HP? I'm running bigs and littles with some skinny bias plys, so I don't think it will hook up and cause too much force on the rear end. I would like to understand the value of using the 40 banjo and understand if I can use the Model A rear end without issue, until I get the other one cut down. Thoughts? Thanks and Regards- Chris
  2. revkev6
    revkev6
    from ma
    first off, yes you can use the model a rear.
    do you want to ?? probably not. the A rears pretty much started at 4.11:1 and went from there! way to low a ratio for the most part. also the A rear has no pinion support. it really can't handle more than the banger has to give. you are also stuck with the stock height in the rear with the stock rear. the 40 rear gets you spring behind the axle. this lets you lower the car quite a bit in the back.
  3. Carter
    Carter
    The model a rear is not quite as strong as the V8 rears, but it will most likely hold up fine behind that 59AB. My buddy Joe has a 32 3 window with a 4 carb 8BA that still has it's stock early 32 rear in it (same as model A in the center)
    There are several other guys on here who have used A rears behind Flathead V8's.
    At the end of the day, it's up to you.
    Sent from my DROID device using the TJJ mobile app
  4. Elrod
    Elrod
    I am because I haven't built my 36 rear with quickchange yet. Agree with revkev on the gears. The engine is screaming at 65 mph.
    It's not going to fly apart or anything. Lay off the burnouts and you'll be fine, until you can't stand not having any top end.
  5. Carter
    Carter
    Oh yeah, I can't say for certain, but I believe there were just as many 3.78 model a rears as 4.11
  6. Elrod
    Elrod
  7. J'st Wandering
    J'st Wandering
    I have a Model A behind a flathead. Has worked fine for me but I also have not beat on it. It has been used for years. I don't know what the gear ratio is but I can run down the road at 70 but the motor is running up high on rpms. I have a tach in it but don't remember what rpms I run it at. I am thinking around 3000.
    Neal
  8. flatford39
    flatford39
    Would really like to see how you put the 8BA in your coupe. I am doing the same thing with my Roadster and I really don't want to cut the firewall if I don't have to. Did you use a mechanical fan or an electric???
  9. Atwater Mike
    Atwater Mike
    My old channeled 'A' Coupe had a 5/16" by stock Ford 59 A-B, '39 trans, Model A rear, 3.78. Built it for a bud in 1958, he sold it, then I bought it from the second owner.
    Ran it at Fremont drags for years, street duty, back and forth from San Jose to L.A., 8 times or more.
    Broke some axle keys, once fractured a spider gear. Replaced it and a carrier bearing, rear was good, tight and quiet 'til we pulled it in exchange for a '40 rear. (1963)
    I was light on the clutch pedal, but the car was always in the low 90s at the digs...
  10. If your really worried you could weld a bung on the axle housing and thread a ring gear support snubber in it to help it a little
    tk
    13 likes this.
  11. Chris
    Chris
    I ran the stock rear in my old coupe, it had a pretty warmed B that would keep up with V8's and I drove it hard. I had stock 3.78's in it, it would do 70 pretty easily but 60-65 was a good cruising speed
  12. chris98006
    chris98006
    from Seattle WA
    Thanks for all the feedback guys! I will post Pics soon. I'm keeping the 40 Banjo and it will go under it within a year or so. I just wanted to make sure there wasn't some huge "issue" with the A rear end, I was missing. Sounds like it should be OK for the time being-
  13. chris98006
    chris98006
    from Seattle WA
    I didn't have to cut into my firewall at all. The fan is a Generator Pulley/Fan, so mechanical. She's tight, but it fits without issue. I didn't want to run electric and try to leave it as "period" as possible, plus it's still 6V.
  14. Search for a thread by Gashog. Never mind, I found it. He uses a Model A rear end. http://www.jalopyjournal.com/forum/showthread.php?t=238505
    As stated above by tub in da dirt, a bronze snubber can be fitted to a Model A rear that stops the crownwheel "walking" under hard acceleration.
    I had a Model A rear in one of my rods in the 60s, held up to abuse ok. It was 3.78
  15. Beecher
    Beecher
    love that frame! cant wait to build mine. what are you using to the rear ****** mount?
  16. Atwater Mike
    Atwater Mike
    Yeah, I like that center cross member too. Is that an F-1 Ford P.U. or '28-'30 Chev???
  17. Elrod
    Elrod
    F1 Ford truck crossmember and F1 pedals
  18. Beecher
    Beecher
    very cool indeed
  19. Bruce Lancaster
    Bruce Lancaster
    The A will likely be fine unless it is real loose from wear. Most were 3.78 like the '40, but check. 4.11 went into some (as well as some '40's...) and that is getting pretty low for a car with no overdrive.
    If you have a decent A rear, there's also not much to lose...converting later to a '40 is going to be the same kob as now.
  20. George Miller
    George Miller
    from NC usa
    most A's have 3.78 gears.
  21. Is the Model A torque tube the correct length for your engine/transmission combination and location in the frame?
  22. hotrodderhaag
    hotrodderhaag
    I had my car all set up with the v8 swap and the factory a rear axle... I decided to go with a 40 rear just because the brakes
  23. Elrod
    Elrod
    If you are using a 39 style transmission with the two feet on the back of the trans, and a flathead and a Model A frame, yes. The Model A rear and torque tube is perfect, and no cutting the firewall or moving the radiator. It's pretty cool.
  24. chris98006
    chris98006
    from Seattle WA
    Rear ****** mounts to the torque tube. Needs a 1/4 inch-ish spacer made to keep from pulling the rear forward.
  25. chris98006
    chris98006
    from Seattle WA
    The 39 ****** will bolt to the torque tube. Need to make a 1/4 inch spacer to keep from pulling the rear end forward.
  26. chris98006
    chris98006
    from Seattle WA
    That would be a great reason to change! I already had juice brakes.
  27. chris98006
    chris98006
    from Seattle WA
    Bingo! The car is at my brothers house. I will see if he can post some pics.
