113 inch wheelbase?
Discussion in 'The Hokey Ass Message Board' started by kustombypook, Dec 10, 2006.
  1. kustombypook
    kustombypook
    I am looking to do a frame swap on my son's 61 Ford Unibody truck. We are looking for a late 70's and up frame with a 113 inch wheelbase. Anyone have any idea what vehicles came with 113 inch wheelbase? Either a car or truck frame will work. Would prefer something with front disc brakes.
  2. Roorda
    Roorda
    from Pella IA.
    why do you whant to swap the frame? on mine i cliped it with a aspen front fit was good i think if i was going to do it agian i would look at the aerostar or dodge dakota truck the only reason is they are easier to find parts are alittle cheaper. if you still want to swap frames i would look at the g-body (79 -87 monte-carlo grand-prix olds cutl***)
  3. Kevin Lee
    Kevin Lee
    Super Moderator
    Here's a dumb question from a guy who knows very very little about these trucks. How do you swap a frame on something that by definition (unibody) doesn't have one?
  4. On that particuler truck the cab and bed are one piece.
    not the body and frame.
  5. kustombypook
    kustombypook
    We have talked about just clipping it. I definately want front disc brakes, and I bought a small block chevy motor for it, so a GM clip or frame is what we are looking for. The reason we are thinking of swapping the entire frame is because if we go with a GM bolt pattern up front, I want to go with a GM rear end as well. It seems easier to just swap the frame, that way everything is lined up.
  6. The Big M
    The Big M
    A 1980's Crown Vic or Grand Marquis is a nice fit. You'll need to cut a hole in the bed to clear the rear suspension though. Makes 'em nice and low. It also gives you the popular 5 on 4.5 lug pattern, so it's easy to find wheels.
    That'll be my next project. I'm looking at a '61 shortbox uni that I intend to drop on an '87 Grand Marquis. You can find a discussion of that particular swap here: http://www.fordtruk.com/forums/viewtopic.php?t=966
    The Aerostar clip is supposed to be a nice fit, but I've heard bad reviews of the Volare (disc brakes and power steering but poor handling). Another option is a '04-up Crown Vic bolt-on K-member, but I'm not too familiar with that one.
    The Dakota clip is good because it is the same track width as the 61-64 F-100's. HAMB'er ElPolacko makes a kit based on the Dakota.
  7. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    FWIW,my dim memory of my stock car racing days in the 70s tells me the early-mid 70s G M (full size) Impalas and such were 112 in. w/b. But I agree with Roorda about clipping it. Think about using a Camero stub as there are TONS of aftermarket a-frames,swaybars,brake kits etc. available for future updates. Is there a reason a G M rear can't just be hung in the back?
  8. Yo Baby
    Yo Baby
    It does have a frame and it is a unibody in that the cab and bed are one unit.
    Unibody is all I've ever heard 'em called.
    Are we havin' a bad day Kev?;)
  9. Kevin Lee
    Kevin Lee
    Super Moderator
    Ha ha. Not at all. Seriously did not know. Always thought those trucks were a true unibody. Lesson learned.
  10. thrasher
    thrasher
    i used a 79 camaro front clip in my truck. has engine and ****** mounts bolt up to it, its easy to find, and you can get them for about 200 bucks. :) i also pulled the brake booster and rear out of a car i paid 100 dollars for.
  11. kustombypook
    kustombypook
    I thank everyone for their input, it is very useful. We were originally going to clip it with a late 70's or early 80's Camero and throw a GM rear end under it. This is my 15 year old son's truck and he wants to do a lot of the build himself, I just figured if I could find a car with the same wheelbase, it would be less work for him on his first build. Either way is fine by me, just trying to make his first one a little easier.
  12. draggin'GTO
    draggin'GTO
    The '68 -'72 GM 2-door A-body cars (Pontiac GTO/Lemans/Tempest, Buick Skylark/GS, Olds 442/Cutl***, Chevy Chevelle/Malibu/El Camino) rode on a 112" wheelbase.
    The Monte Carlo and 4-door A-bodies had 116" wheelbases, you could shorten one of these to 113" if it's worth the trouble to you.
    Disc brakes came on quite a few of them, optional equipment. Full-size GM B-body cars (Impala, Bonneville, Ninety-Eight) had considerably longer wheelbases.
  13. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Brain Fart! Your right, it was the midsize with 112 and the Cameros etc. with the more desierable (for oval racing) 108 w/b Thanks.
  14. The Big M
    The Big M
  15. kustombypook
    kustombypook
    I know this was an old post, but I have seen some similar post lately asking about Ford Unibody trucks so I thought I would bring it back up.
    We are using a 1985 Crown Vic for the frame, power train and pretty much everything else except for the body. We have a rolling ch***is now for mock up, and once we get all the floor done in the truck cab, we are gonna get a running Crown Vic and pull the body and drop the truck body on that frame. We are going to try to use as much as we can from the car, including all the wiring. Should be a fairly easy swap.
  16. fiftyv8
    fiftyv8
    from CO & WA
    See Industrial Ch***is Inc website, he (Steve) is a Hambster and does great things with pickups in the suspension department. He does a front cross member that accepts Dodge Dakota front suspension stuff which has a ford car stud pattern or just replace the rotors with drilled stud to your needs.
    Dakota will give you a choice of 6 cylinder or V8 coil springs, disc brakes and power steering, otherwise Jaguar or Crown Victoria aluminum front suspension looks trick and you dont need all the work that may come with a full clip if you are not up to it.
  17. ELpolacko
    ELpolacko
    [smirk] Yeah I could hook you up [/smirk]
  18. super thread BUMP! so what ever happened to this? I have the same issue. 85 crown vic roller that ran and drove 3 days ago, need another body on top! looking into ford trucks right now. :D
  19. Matt steele
    Matt steele
    1940 chevy master deluxe coup has 113" WB ..JUST an FYI
