'64 and '65 Nailhead Tranny
Discussion in 'The Hokey Ass Message Board' started by oldwood, Sep 3, 2012.
  1. oldwood
    oldwood
    from arkansas
    I looked at a '64 and '65 LeSabre they both had nailheads and 2 speed auto ******s. Then I look at a 4dr '64 Wildcat that also had a 2 speed ******. I been reading the info on the HAMB that I need to look for 64-66 Full size body cars and they will have the ****** that is compared to the TH400. But all the shifters said L and D . The wildcat had a 4bbl carb. Did I miss read something???
  2. slimpick
    slimpick
    Any 64 to 66 nailhead would have a ST400 3 speed auto behind it. Are you sure the LeSabres had nailheads and not the smaller V8 of that period.
  3. Dynaflow PNDLR
    ST400 PRNDL Low is first OR second depending on your speed when you shift into it.
  4. chubbie
    chubbie
    the early buick switch pitch 400 shifted from "L" to "D" It used second gear as a kick down for p***ing gear.
  5. 390Merc
    390Merc
    from Indiana
    You will only see L and D on the shift indicator!! When you take off in D you are starting in first, the car will shift into second, then third just like any other turbo 400.
    You can downshift manually into L at any time and depending on the car's speed at the time, it will drop into second or first.
  6. oddrodron
    oddrodron
    from virginia
    I have a 64' nailhead 400 out of an electra 225 if you need one?
