Stock fuel pump with dual carbs?
Discussion in 'The Hokey Ass Message Board' started by olskool34, Apr 11, 2013.
  1. olskool34
    olskool34
    I have looked and all I can find is electric pumps for dual carbs on a flathead. Will the stock fuel pump handel dual carbs? I would really like to keep the stock pump if I can.
  2. R Pope
    R Pope
    It ill work as well with 2 carbs as it did with one....They are not the best pump by a long shot, but they have worked for decades.
  3. 226 flattie
    226 flattie
    from orange,ca
    They work fine. No problems. Be sure to add a fuel pressure regulator . 3 lbs is what they need .
  4. junk yard kid
    junk yard kid
  5. olskool34
    olskool34
    Thanks guys, didn't want to go and get an aftermarket pump If I didn't have to.
  6. Olschool. I think that a lot of the fellas if they need to buy a fuel pump anyway decide to upgrade. If your stock fuel pump is in good shape it should handle a couple of old Ford carbs just fine.
  7. 40FordGuy
    40FordGuy
    Yes, it'll work, and a regulator is a must-have, set to no more than 3 psi.
    4TTRUK
  8. Shaggy
    Shaggy
    from Sultan, WA
    Basicly it isnt like you are going to be running more fuel thru your motor, atleast other that the little bit of gained air flow you get from the multiple carbs at rpm... What i mean is the fuel/air ratio stays the same, you just pull slightly more air, and slightly more rpm(also more air/fuel), but the rpm is mostly negated by increased fuel pump strokes per min
  9. R Pope
    R Pope
    No need for a regulator if it worked with the original carb without one. Adding another carb won't change the pressure. Never seen a flattie that had a reg.
    V8-m likes this.
  10. tommy
    tommy
    I'm running 2 97s on my Studebaker with no regulator and a factory fuel pump. I ran 2 on my flathead but I used an electric pump and a regulator. Each carb only delivers 1/2 of the fuel for any RPM so there is no problem.(after they are synchronized) The problem comes in when an electric pump is added usually putting out excessive pressure overcoming the needle and seat.
  11. HotRodMicky
    HotRodMicky
    I feed 3x97s on 304 ci with a stock pump.....
  12. Cliff Ramsdell
    Cliff Ramsdell
    Same here, I run a stock mechanical pump with 2 carbs and no issues. I don't run a regulator either, stock ford pump, stock ford carbs.
    Cliff Ramsdell
    V8-m likes this.
  13. jimmygrrr
    jimmygrrr
    I just had to grind some off the fuel pump rod and play with a couple different gasket thicknesses to get the pressure correct. I'm running an old edmunds intake on my flathead with 2 94s. Set it to 2.5 lbs and never had to touch it again. No need for a regulator if you set it up right.
  14. kennb
    kennb
    I've run 3 with no problems before. You'll be fine. Ken
  15. cully33
    cully33
    I'm running 4 x 97s with stock mechanical pump on my flathead with no regulator on my 32 no problems at all.
  16. Kirk Hanning
    Kirk Hanning
    (3) 97's on a Hemi with a stocker pump, it's good ta go.
  17. pbr40
    pbr40
    from NW Indiana
    What kinda of fuel pressure regulator are you guys running? I bought a Holley and it looks and feels real cheap! Thanks
