Odd-format tachs
Discussion in 'The Hokey Ass Message Board' started by Ned Ludd, Feb 24, 2011.
  1. Ned Ludd
    Ned Ludd
    Speedometers in formats other than round with a needle sweeping around a central pin are common enough. There are horizontal 90° sweeps, 180° sectors with or without something in the middle, drums vertical and horizontal, rotating dials, and ribbons. I'm sure there are others I can't think of right now.
    Odd-format tachs are less common: but I'm thinking in that direction for the Morris Minor. It's got a central round speedometer with inset fuel gauge, and I'll want battery, temp, oil pressure, and a tach in front of me. I'd like to do something in the idiom of the immediate post-WWII era, but also with a touch of idiosyncracy to it.
    The plan is for a resin panel that fits in place of the driver's side glove box door and holds a gl*** window, with all the above gauges behind it. Beyond that I'm suffering a temporary imagination loss: I can't see how those would be arranged in the strange triangularish space - but that will come.
    Now, I've got an 80mm VDO tach in the car, and I'm wondering if its movement could be used to drive some sort of odd-format tach, a ribbon or a drum or something just a bit unusual. Is this sort of thing viable? If so, can someone throw me something to get the old creativity going?
  2. Ned Ludd
    Ned Ludd
  3. batt69nova
    batt69nova
    from OR
    Perhaps it'd be easier to settle on the shape of the tach or the style first, or is that the problem-can't settle on the style/shape?
    Seems to me like it'd be easier to figure out how to make it work after settling on the design.
    Horizontal seems sounds interesting, but maybe hard to read.
    Maybe something with an odd sweep like this:
    http://www.google.com/imgres?imgurl=http://www.airminded.net/nstdd25/d25nat_airspd_ind.jpg&imgrefurl=http://www.airminded.net/aeroncac3/c3borneo.html&usg=__Y8AEJ618-icFaY4u41XUsu4YWQc=&h=732&w=800&sz=61&hl=en&start=45&zoom=1&um=1&itbs=1&tbnid=N-e5lGfy9m0e7M:&tbnh=131&tbnw=143&prev=/images%3Fq%3Dairspeed%2Bindicator%26start%3D42%26um%3D1%26hl%3Den%26safe%3Dactive%26sa%3DN%26ndsp%3D21%26tbs%3Disch:1&ei=5upmTezGBYr2swOdht2oBA
    You mentioning WWII made me think of altimiters...the kind that have a "vertical roll" (if that the right way to describe it...) with a solid line on the lense face. Having a really hard time finding any images of those.
  4. i like cars & stuff
    i like cars & stuff
    from Aotearoa
    You think like i do. Make an odd tach from a normal one. Subbed
  5. Mowogler
    Mowogler
    from UK, Surrey
  6. ceegrey
    ceegrey
    Many British aircraft such as the Avro Anson, Airspeed Oxford etc used a verticle rolling style mechanical engine RPM instrument that should adapt. These are still reasonably common and often turn up in collections. Should still be a few floating around in S.A, luck with it.
  7. crashfarmer
    crashfarmer
    from Iowa
    1970-71 Ford Torino's had a different style tach.
    <iframe width="560" height="315" src="http://www.youtube.com/embed/LfTRhQyp1EQ" frameborder="0" allowfullscreen></iframe>
    http://www.youtube.com/watch?v=LfTRhQyp1EQ
  8. outlaw256
    outlaw256
    now theres one i didnt know about. dont really like it either,thou it is different...
