37 ford coupe tail lights
Discussion in 'The Hokey Ass Message Board' started by roadster1234, Apr 11, 2013.
  1. roadster1234
    roadster1234
    hello all would anyone have a idea what the rear taillight mount height on a 37 ford coupe be, doing a street rod old school taillights, if pictures are avalible please send thanks send to roadster601@aol.com
  2. It depends upon how much air is in the tires. All kidding aside, what do you want? Height from ground, distance from end of fender? What picture, from side of car? I have a tape measure and camera but only enough time to do it once.
    Charlie Stephens
  3. roadster1234
    roadster1234
    thanks charlie i guess a picture on side and looking at rear light fron trunk to use as reference and i guess a measure from tailpan bottom to bottom front of light mount
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    Just take exact measurements with momma's cloth tape at your left hand fender tail light and get the drill out. Run the measurements up from the bottom of the fender, from the whell opening and the edge where it meets the body.
  5. roadster1234
    roadster1234
    thats good if i had a reference point or hole what is that reference point in inches
  6. HOTRODPRIMER
    HOTRODPRIMER
    I have been scratching my head trying to figure out why you sent me a PM about 37 tail lights,,now I knew you are looking for a reference point on a coupe.
    I have 37 tail lights on my 32 pickup so I'm sure I can't help with the position of the lights. HRP
  7. roadster1234
    roadster1234
    does anyone in hamb have a 37 ford coupe with rear standard taillights mounted to there fenders please get back to me thanks
  8. Stevie Nash
    Stevie Nash
    Old school street rod???
  9. Petejoe
    Petejoe
    from Zoar, Ohio
    Huh??? You use the opposite fender for your reference point. Don't you have a left hand fender?? You need some one do the work for you?
    You are speaking to someone who has a 37 coupe with an original left hand taillight who installed a R/H tail light on his right hand fender.
  10. The center of the tail light lens on my '37 Ford Coupe is 23 1/2 inches above the ground. The bottom of the fender (which is the same height as the tailpan bottom) is 13 1/2 inches. Therefore the center of the tail light lens is 10 inches above the of the tailpan bottom.
    Charlie Stephens
  11. Petejoe
    Petejoe
    from Zoar, Ohio
    I think he wants you to get out your (old school) drill and drill it for him Charlie. :)
  12. roadster1234
    roadster1234
    theres never a shortage of ??????
  13. roadster1234
    roadster1234
    to all who really tryed to help me thanks
  14. Petejoe
    Petejoe
    from Zoar, Ohio
    You're starting on the wrong foot there buddy.
    If you want help from here on out you have to explain yourself.
    We all tried but you seem to not get it.
  15. The bottom point of the stock mount is 5 1/4 inches from the seam (measured perpendicular to the seam) and 5 1/4 inches above the bottom of the fender. You might want to find a loose fender and make a template since there are a lot of curved surfaces.
    Charlie Stephens
  16. DD COOPMAN
    DD COOPMAN
    Damn Charlie, that's just about almost exactly the same as mine. DD
