Fusing fiberglass to metal body
Discussion in 'The Hokey Ass Message Board' started by Styleliner, Apr 13, 2013.
  1. Styleliner
    Styleliner
    Is it do-able? Will it hold up? I wonder if I could form a cab corner from fibergl*** if I backed it with wire mesh or chicken wire spot welded to the metal body?? If this is possible it would make life a little easier for this broke guy.
  2. Mr48chev
    I'd just bond the fibergl*** to the steel body in the normal bond figergl*** parts to steel process.
    What kind of cab? in the long run it will probably cost less to find a decent usable cab corner and weld it on.
    If GM AD 47/53 cab corners will work I will have the back half of a cab left over when I cut the two I am using for my stretched cab that might work. I haven't cut them yet but need to so I can get started on that. It's about a 116 mile road trip up here to Top*****h from Walla Walla and we can trade chickens for ducks if you have something to trade. I've also got another cab that has the roof cut off that might work better, same trade.
  3. Styleliner
    Styleliner
    Its one of those car to pickup conversions, I can do it with metal but thought fibergl*** back would be a lot easier and cheaper (except for the needed sanding). Im going to chop top 3 inches first then fabricate a "Back of cab". I imagined I could create a good form with fiberlg*** sheets and chicken wired curvers and laminate more gl*** over the top. But would it stay put?
  4. 52plybizcoupe
    52plybizcoupe
    from Brier Wa.
    you are better off in the long run to find a back of a cab to fill that in
  5. Styleliner
    Styleliner
    I suppose your right but once chopped there wont be much cab to put on... and behind the bed is going to be flat sheet with wraparound curved side corners pretty much.
  6. Styleliner
    Styleliner
    An entire straight back would be easiest but wont look very clean. Just chopped in half.
  7. G-son
    G-son
    from Sweden
    A "hard joint" between fibregl*** and metal likes to crack and separate in time. Joining them together with a flexible glue (polyurethane type for example) and perhaps pop rivets is more likely to work in the long run, but does not look very good.
    If possible, I'd avoid mixing fibregl*** and metal.
  8. Mike51Merc
    Mike51Merc
    Be sure to post pictures of your progress.
  9. Styleliner
    Styleliner
    116 miles not so bad... Could you post a pic of these corners and cabs? I have styleline parts trunk, steeringwheel, trans, rear bumper, cash?? Thanks for the offer.
  10. 296 V8
    296 V8
    from Nor~Cal
    :rolleyes: JB weld and dryer sheets is the hot setup ;)
  11. Styleliner
    Styleliner
    I don't think your kidding... Sounds possible and crazy! LOL! Genius.:)
  12. Morgan91
    Morgan91
    from Australia
    I'd use steel, sounds harder but in the long run will be so much easier and will hold up better and probably. Be cheaper to.
  13. n.z.rodder
    n.z.rodder
    Some pics of how bad the corners are would be helpful, A polyurethane adhesive is the way to go, but it will probably cost more for the fibergl*** kit and the urethane than a steel replacement.
    Scotty
  14. Styleliner
    Styleliner
    Yeah steel probably best im convinced... I was just daydreaming I suppose. Thanks. I don't want the straight back like a chevy Luv, although I could probably do one in a day or two.
  15. Seriously, use steel. Anything else is temporary not to mention total hack work.
  16. Styleliner
    Styleliner
    Done... Im interested in previous posters corners... A trip to pick a part may help. Don't think I have the skills to fabricate round corners. Would it be wise to tack in all my flat sheets and supports first and then cobble the corners in? Hmmm... still brainstorming.
  17. tb33anda3rd
    tb33anda3rd
    where are the body parts you cut off? they will have nice tight round corners and edges to to fabricate the back of your "cab"
  18. Styleliner
    Styleliner
    I sat out in the yard staring at all that stuff and came to the conclusion that would not be so easy. With My limited skills I could do all but the 4 corners... I can do the 90 degree bends off the roof and the sides with supports behind them... But the round corners... yikes. I wonder if any company sells a standard 18 ga. sheet corner?
  19. 52plybizcoupe
    52plybizcoupe
    from Brier Wa.
    find a mid fifties truck thats rusted out on the bottom you sound like you just need the upper cab corners for the roof area if you get a whole cab you could use the four rounded corners of the roof to fill in where you need
  20. Styleliner
    Styleliner
    Yep... That's the ticket. (But I still want to learn more about Dryer sheets and JB weld... ) :D
  21. tb33anda3rd
    tb33anda3rd
    forget the dryer sheets and jb weld. your going through all the trouble of building this custom body you should do it the best way possible, so it doesn't come out ****py. custom stuff only works when it looks like a craftsman/artist worked on it. as soon as a crack, chipping, or pealing appears, it will discount all your effort.
  22. Styleliner
    Styleliner
    I agree... I think the JB weld guy may have been pulling my leg, but I bet that would work for smaller patches in areas not so visible.
  23. black 62
    black 62
    from arkansas
    don't questions of this type usually come from michigan or new york ? sounds like rust belt technology---use steel ,you will be satisfied with the result...
  24. flynbrian48
    flynbrian48
    This is on the 50 Chevy sedan to pickup you started a thread on earlier? Sounds like you have a pretty steep learning curve ahead...
    I'd look for an early Chevy pickup cab back, and use the whole thing, and if you found a 5 window, so much the better. It'll always look like a cut up sedan if you try to use the C pillars you lopped off, whereas a truck cab back would look, well, like a truck.
    Brian
  25. Styleliner
    Styleliner
    This is very true and I'm not ashamed to admit it... But Im enjoying this a whole lot and tossing ideas around. You'd be surprised how much I've learned since finding you guys here. This is only my 2nd project car... years ago I put together a fairly simple simple 69 Baja bug. No big deal, I know... Learning is good. I pay attention and read lots of threads by you guys and understand that some of you are hard core pro's... Lets just say I'm tagging along, and hoping to surprise with a decent low budget and (different) project.
  26. studeynut
    studeynut
    Do not use fibergl*** on steel. They both have different expansion rates with tempature changes. They will seperate. Only way it would last is if it was kept in a tempature controlled enviroment. Have peeled fibergl*** from several past projects to find rust underneath.
  27. I know a guy who uses PL800 to bond panels in- lap joint and pop rivet it at intervals and then he cuts off the rivet heads and muds up the joint
  28. bbc 1957 gasser
    bbc 1957 gasser
    3m makes a glue for it just did a tear drop scoop on a 55 chevy hood its around 50 bucks but its good stuff .
  29. flynbrian48
    flynbrian48
    Yes, and it's good stuff, but he needs to make the panels FIRST before bonding or welding them to his car/truck/ute project.
  30. reverb2000
    reverb2000
    from Houston TX
    Its ok to bond...look for something called Corvette glue...that may be a generic name, but seems it was a two part epoxy...my friend used it building those Ferrari bodied 280z's. I have seen some 20 yrs old and look fine.
