Projects My new project '40 Ford coupe (60's style)
Discussion in 'The Hokey Ass Message Board' started by Russco, Nov 5, 2012.
  1. Russco
    Russco
    from Central IL
    I'm hoping the shifter will work in that position, it may need to go forward yet. I have heard the shifter's feel isn't as good from the middle location so Im going to try it there and hope I dont have to move it forward, its going to be close up to the bench seat though.
  2. 34toddster
    34toddster
    from Missouri
    I talked to a guy at the World of Wheels show last month in Kansas City and he makes a shifter to move forward from your posinion another 2 or 3 inches for $280 a lot less than the close to $500 for TKO. So he says. He is a dealer for TKO and somehow involved with Tremec, if you want I'll find his business card so you can contact him, he in Texas I believe!
  3. Russco
    Russco
    from Central IL
    Yes I would be interested in that, thanks
  4. 34toddster
    34toddster
    from Missouri
    Here is the info Russco, DEDERICHS Motorsports, Joe, jdederichs@yahoo.com or 682-365-5555
    I thought he knew his stuff, be worth a call. Let me know what he says.
  5. Russco
    Russco
    from Central IL
  6. rob lee
    rob lee
    from omaha,ne
    Nice build as always!
  7. dualquads
    dualquads
    wow, real size hot wheels !
  8. Russco
    Russco
    from Central IL
    Thanks Rob, If it turns out anywhere close to as nice as Gary's 40 I'll be tickled.
  9. Russco
    Russco
    from Central IL
    Got the rear end back in, I'm posting some pics for Murph (VintageAuto) of the CE rear Leaf set up. A couple notes for Murph. I chose to weld the brackets on rather than bolt them. The CE front hangers when bolted on wont work with the rear boxing plates as they need to bolt on to the upper lip of the frame rail. Rather than cut the upper part off since Im not bolting it to the rail, I will use it to mount a driveshaft hoop from. The CE stuff went on just as its supposed to the only things to note was the upper shock mounting brackets needed to be spaced forward about 3/16ths from the crossmember at the top when welded or I guess you could bend them forward a bit otherwise they tend to run uphill and not match up to the shock eyes very well. You will also need to clearance the lip on the crossmember a bit for the shock body and I had to for the 9" pumpkin to clear the lip of the crossmember too. I hope this helps you Murph.
  10. Hey Mike...Thanks, it does help. I've saved the pics and lightened them up a little. Setup looks great!
    Murph
  11. olscrounger
    olscrounger
    Very nice job--looks like you got a great 40. On every CE rear kit I have installed, the rear wheels are off in the wheel well about 3/8 to 1/2 inch to start toward the rear. You are making great progress.
  12. wastren
    wastren
    from illinois
    Russco ur cool so are all ur projects
  13. Kan Kustom
    Kan Kustom
    I`m with you on the 60`s style. I am building a 60`s style drag 40 standard coupe.
  14. Pewsplace
    Pewsplace
    Looks good to me. Nice and clean work. It is hard to beat a 40 Ford for a great road car.
  15. rd martin
    rd martin
    from indiana
  16. Rusty
    Rusty
    Here's mine, gotta love a 40
  17. Russco
    Russco
    from Central IL
    I missed this when you posted it Rusty, I saw it at Joplin and was really digging it. I know you had to thrash to get it back together in time to make the drags. Hope mine turns out as nice.
  18. Russco
    Russco
    from Central IL
    I have kind of taken the last couple months off from working on it much. I have made some progress though. The bottom end is done on the motor and I should be finishing it altogether in the next couple weeks hopefully. I also took the body to Jay (Da Tin Man) to have him work a little magic on the bad spots in the floor and where the "A" pillars meet the floor that had a little rot in them. He did an awesome job. Now I have a few odds and ends to do on the body then its going to my buddy Brad's place for paint and body work while I focus on the mechanicals.
  19. Russco
    Russco
    from Central IL
    BTW these front pans are Full length Bradley pans cut up to use just what was needed to repair the bad areas. I ordered short front pans from Bradleys in February, I still haven't received them. I asked for a refund in June still haven received that either. The pans are nice but if I knew it would take who knows how long to get them. I would have done something different. Luckily a HAMB'er Bill Nabors had an extra set he sold me. I just had to drive 600 miles one way to pick them up. Other wise I guess I'd still be waiting for my pans from Bradley.
  20. Pewsplace
    Pewsplace
    The patch work really came out nice. Lots of welding to do it this way. I had the Bradley Pans for many years and finally put in the complete Drake pans which was also a lot of work. The car should be a real nice ride when finished.
  21. Deadbird
    Deadbird
    This thing is gonna be sweet Mike. Have you settled on the color yet?
  22. Russco
    Russco
    from Central IL
    The color will be real close to this Lee.
  23. Deadbird
    Deadbird
    Excellent choice my friend!
  24. Russco
    Russco
    from Central IL
    I have been able to get some progress done recently. The motor is all but finished a few little things yet, Distributor, Carburetor, Flywheel, Starter, water pump ETC. It's not very period correct with the aluminum heads, but should make some pretty good power and be street friendly still. I still need to figure out the breather/PVC system though.
  25. Russco
    Russco
    from Central IL
    I also got the floors painted with POR15. Got the firewall set up for the swinging Brake/Clutch pedals and sent the body off to my buddy Brad for him to do the bodywork and Paint.
  26. 34toddster
    34toddster
    from Missouri
    Looks Great Russco, may I ask where you bought the front floor patches
  27. Russco
    Russco
    from Central IL
    Well I bought them from a fellow Hamb'er Bill N. He had an extra set lying around. They originally came from Paul Bradley in N.C. (Bradley Floor Pans). I'm still waiting for the ones I ordered and paid for from Bradleys' about 10 months ago.
    http://www.jalopyjournal.com/forum/showthread.php?t=808969&highlight=bradley
  28. 34toddster
    34toddster
    from Missouri
  29. Brokenwrench Rod n Custom
    from East TN.
    Hey Russco, 40 is looking great! you mentioned building it 60s style. heres some pics of my Jersey car..... same garage for over 30 yrs. unchanged since 1965 build. 327/300, T-10, 5:38 gears ina tri 5 housing. I freshend the brakes, fuel system, and some wiring and been driving all summer! Its a rush laying black marks with 40yr old redlines!
    neilswheels and falcongeorge like this.
  30. olscrounger
    olscrounger
    nice job, nice progress--love them 40's--gonna go look at another one in a week or two--keep up the great job.
