300 hp 327 with 2bbl intake? WTF?
Discussion in 'The Hokey Ass Message Board' started by redlineracer42, Apr 9, 2013.
  1. hoop98
    hoop98
    from Texas
    That is correct except for 69.
  2. jcmarz
    jcmarz
    from Chino, Ca
    True and with a 427. The last true SS Impala (69), just like the first SS Impala (61) both had hot engines.:)
  3. 59Apachegail
    59Apachegail
    from New York
    I just picked up a repopped set for my 283 rebuild. I had original ones on power pack heads.
  4. Tanks Gary!
  5. blowby
    blowby
    from Nicasio Ca
  6. 59Apachegail
    59Apachegail
    from New York
    Very welcome blowby but this also adds another level of complexity here. Everyone is talking about camel humps and I have power packs. Also I think my 283 is 65 from a brookwood or Biscayne. Mine seems 2bbl original as all the date codes match.
  7. studebaker46
    studebaker46
    back in the day there were more than you would think hell i even seen 64 convert ss with 6cyl powerglide yellow it was achicks car so you never know tom
  8. bobbyjamesf1
    bobbyjamesf1
    It's called sneaky! We used to cut the chrome "CI" emblems off the fenders too. Never advertise what ya brung!
  9. Larry T
    Larry T
    So, when did 283s (or 307s) come from the factory with "double hump" heads. I thought the biggest head they ever used was the "power pack" head (until 1967 on 283s, and didn't 307s have the bolt holes in the end of the heads?). I'm thinking that even the fuel injected 283s had "power pack" heads with 1.72 intakes. The first "double hump" heads were on 327s.
    As far as the exhaust bolt locks, I don't remember many mechanics putting them back on when they pulled the manifolds. They were kind of a pain to work with for a line mechanic, getting stuff out as fast as possible. So even if the engine is original (I don't think so, Tim), if it's ever had exhaust gaskets put on it in the past 50 years the locks are probably long gone.
  10. theHIGHLANDER
    theHIGHLANDER
  11. sunbeam
    sunbeam
    63 had both Small stick early 63 with warner T10 fat shifter late with muncie.
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    For the record, 1961 315HP 283 'vettes came with double hump heads.
  13. Larry T
    Larry T
    I learned something new today, that's a good thing. Now if I don't forget it so I'll have to relearn it tomorrow.
    Looks like there were around 1500 of these built? All with 461X heads?
  14. hoop98
    hoop98
    from Texas
    As did the 275 hp 283s
  15. Dick Stevens
    Dick Stevens
    The 63 Impala SS that I ordered new came with a factory tach, with a 5200 RPM redline, if I remember correctly, mounted in the center of the dash and the four speed shifter had the short fat rod with small white knob for Muncie close ratio trans. This may not be a true SS
  16. fastcar1953
    fastcar1953
    i know its a old thread , but i just read seven pages and never found out what engine it was. answers i need answers....
