Rear end swap 1928 Ford, what happens to leaf springs?
Discussion in 'The Hokey Ass Message Board' started by JoeJack36, Apr 16, 2013.
  1. JoeJack36
    JoeJack36
    Evening gentlemen, just go into this whole forum ordeal and had a question for all you hot rodders. Were putting a newer ford rear end into our Tudor, and was wondering what happens to the leaf springs connected to the original rear. Do we discard them and add coils?
    Thanks for your time,
    Joe
  2. F&J
    F&J
    Ordeal? stick around, and see what happens :)
    Traditional site that this is, I'd say most hambers would want to use a transverse rear spring. Coils and coil-overs will work...but..
  3. Mr48chev
    Well. if you haven't already got a plan I'd suggest either snagging some hot rod ch***is books or finding someone competent to do the work.
    The quickest way to ruin an old car when trying to upgrade it is not having done your home work in advance. There are plenty of Model A build threads on here and plenty of how to Hot Model A Ford books floating around.
    My Model A will use the transverse spring and a pair of radius rods running up to a cross member with a later rear axle but others have done it a number of ways.
  4. kirby1374
    kirby1374
  5. Texas Webb
    Texas Webb
    As above read and search.Both will gleen much usefull info.
  6. After the intro, tell us what you have. You say you want a "later" Ford rear end. How late? What's in it now, the original A unit? What engine and trans do you have or want to use? Don't be stingy with the information.
  7. BobF
    BobF
    from Poway, CA
    I will agree with the previous posters and you need to read up on what your planning to do.
    That said, there are several ways you can go. I have a 31 Model A with a Olds rear with the original transverse spring. We have a 28 rdst with a Mustang 8" rear with coil over shocks. There are still other ways to go, maybe 1/4 elliptic springs? Regular coil springs?
    The problem with the A is the frame ends directly over the center of the stock rear, so there is no part of the frame behind the stock rear location to attach parallel leaf springs shackles.
    Good luck with your project, you''l figure it out.
