Weak brakes on 30 Roadster Survivor
Discussion in 'The Hokey Ass Message Board' started by Troy Gemmer, Apr 16, 2013.
  1. Troy Gemmer
    Troy Gemmer
    Just got back from having the brake system flushed and checked over, but the brakes are still weak. This rod was done over 50 years ago and is untouched. All four wheels are drum brakes and there's a 'wagner' master cylinder (pictures included) that looks like someone upgraded to try to deal with the problem. At this point, I can't stop quickly, and you have to step hard to slow down. Any thoughts or ideas?
  2. mikeallcars
    mikeallcars
    Did u have the drums turned ,and check the brake lining ?
  3. Troy Gemmer
    Troy Gemmer
    No I didn't. I think they just blew out the cobwebs. They did fix a small leak on one of the pistons by reaming it out and putting it back together. Thank you for your help.
  4. Troy Gemmer
    Troy Gemmer
    Sorry, the brake pads themselves looked like there was lots of wear left, but they didn't turn the drums...
  5. pasadenahotrod
    pasadenahotrod
    from Texas
    Check drums for thickness. ID should be no more than 12.030". That is .060 oversize.
    Linings may be crystallized or glazed and thin if the drums are oversized too much.
    It is foolish to blow out the cobwebs and ream out a cylinder and then go riding. 50 years of sitting does not make for safety in brakes under the best of cir***stances. You should rebuild or preferably replace with new all the wheel cylinders, master cylinder and especially the three hoses for the brakes. To be thorough a new set of steel lines wouldn't hurt a bit.
    I value your life, that of your p***engers more since they are innocent, please value the life you have and that of those you may come into contact with on the rods.
  6. Need to check the pedal ratio .
    Some math and measuring.
    Try to rebuild, repair what you have.
    I doubt anything you get today will be of equal quality.
    Try really hard not to disturb the "survivor " aspect . That's cool as hell
  7. biggeorge
    biggeorge
    You really should go right through the brakes. you could have clogged lines or bad hoses. Skidmarks is right about frozen pistons in the wheel cylinders. Take the brakes apart and rebuild all the cylinders check the fluid flow from all the lines and sand down the shoes as they may have some oil on them. The car in front of you has much better brakes and even when you have good brakes they will stop a lot faster than your roadster.
  8. 210sedan
    210sedan
    from upnorth,wi
    replace the lines+hoses,and everything else,50 years is along time
  9. HOTRODPRIMER
    HOTRODPRIMER
    Do it right,don't wreck the car because you don't know how or trying to avoid rebuilding the entire system.
    50 year old rubber hoses are week and may be causing part of the problem.
    Turn the drums and replace to brake shoes and wheel cylinders. HRP
  10. rld14
    rld14
    Jeez,
    I'm planning on replacing the lines and hoses and re-sealing the calipers on the girl I've been seeings OT 2002..... Because, IMO, that stuff is now too old to use.
    And this thing was built over 50 years ago? REPLACE OR REBUILD EVERYTHING THAT GETS IN CONTACT WITH FLUID!!!!!!
  11. WillyNilly
    WillyNilly
    from NorCal
  12. WillyNilly
    WillyNilly
    from NorCal
    White Post is good too, but I'd stay away from Apple Hydraulics. If you send him your pistons, he'll buff them out too and they'll look like new.
  13. GEBHARD
    GEBHARD
    from TX...
    Im glad someone actually picked up that roadster its pretty rad
    I saw it on c.l. Seem'd like a great deal for what they were askin
    For it. Congrats
  14. Don's Hot Rods
    Don's Hot Rods
    from florida
    Start from scratch right at the MC and replace or rebuild every component in the system. Only way to do it right, and that cool rod deserves the best, it is really super nice. :)
    Don
  15. Troy Gemmer
    Troy Gemmer
    Thanks for the reply. The rear/differential is an old ford I think.
  16. Troy Gemmer
    Troy Gemmer
    Appreciate the advice. Looks like Sierra is retired - any other leads? Thanks again
  17. Troy Gemmer
    Troy Gemmer
    Didn't consider oversized drums - thx
    I'm definitely being cautious...
  18. Troy Gemmer
    Troy Gemmer
    I'll check with the shop tomorrow to see if they adjusted them. Also, if they checked for seized cylinders. TY
  19. Troy Gemmer
    Troy Gemmer
    A big thank-you for all the input!
  20. WillyNilly
    WillyNilly
    from NorCal
  21. Austinrod
    Austinrod
    from Austin
    Mine is the same as yours a fifties survivor 31A roadster and my brakes need rebuilding too they are hard too stop.
    .......Sent from Ar
  22. Troy Gemmer
    Troy Gemmer
    No, they're poor even if you really pressure hard on the petal...
  23. Troy Gemmer
    Troy Gemmer
    You might be right about the ratio too - especially since the master cylinder was cheaply swapped out
  24. Troy Gemmer
    Troy Gemmer
    Nice car! I sure like the look of these old lowboys.
    Hmmm I'm wondering if they ever stopped good...
  25. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    As someone mentioned earlier it could be that it never did stop very good
    I would check the brake linings and the drums to see if the brakes shoes have gotten crystilized/glazed over which used to happen alot back in the day, this would make the brake pedal seem hard to push since you are really standing on the brakes to try and stop.
    neat ole car and good luck
  26. Troy Gemmer
    Troy Gemmer
    Thanks for your comments. I'm thinking more now that the master cylinder bore doesn't match as you suggested and don't think the wheel cylinders are sticking. I haven't figured out any more on the transmission to answer your question. Thanks again.
  27. Bearing Burner
    Bearing Burner
    from W. MA
    Wheel cylinders should be an easy find for a Ford. The fire wall on the roadster was not made for master cylinder and may be bowing from pressure of brake pedal . Also check that brakes are adjusted correctly.
  28. junk yard kid
    junk yard kid
    Did you just pic this up? Ive seen it on clist. Nice looking car.
  29. Jamoke
    Jamoke
    Killer Ride
  30. Troy Gemmer
    Troy Gemmer
    Yeah, just bought it
