hudson VIN ?
Discussion in 'The Hokey Ass Message Board' started by whiskeymakin, Apr 17, 2013.
  1. whiskeymakin
    whiskeymakin
    from mid tn
    I recently got the ol hudson commodore up and running, its a 49 model to the best of my knowledge. the vin plate has been long gone, i bought it without a ***le. All i have is a bill of sale.
    what should i do about a vin #?
    thanks!
  2. damagedduck
    damagedduck
    from Greeley Co
    here we have police/sheriff/hiway pol, inspect them and they have books of where to find hiden vins.
    And go do a Intro ;)
  3. whiskeymakin
    whiskeymakin
    from mid tn
    thanks! i will check on that. im in TN and the problem is insurance....they want a VIN. the dmv will issue a ***le without one
  4. damagedduck
    damagedduck
    from Greeley Co
    There should be V.I.N #'s stamped through out the frame & body,
  5. Razorshotrods
    Razorshotrods
    from Phoenix
    REALLY? Find that hard to believe. Seems everyday there is a ***le ? on here. Try the search.
  6. Street Is Neat
    Street Is Neat
  7. tfeverfred
    tfeverfred
    Or call your local DMV.
  8. I got an open 46 historical do***ent!
  9. Verminator
    Verminator
    check the p***enger side door jam near the top door hinge. That's where it's located on the 50 commodore I had.
  10. whiskeymakin
    whiskeymakin
    from mid tn
    ive searched the car over, its had lots of body work. the door plate is long gone. and no luck on the frame. still got to check the rear axle.
    the deal with a tn ***le is like you are building a kit car....different motor applies to that rule. which in this case i have a 318/727.
    i would like to keep it original if i can, but may not happen.....the vin original that is
  11. Hud I
    Hud I
    from Tennessee
    With out the original motor, which has the same # , the best bet is to look at those places suggested by the thread over on the Hudson board at Cl***ic Car. Good luck on the ***le. Hud
  12. patrick66
    patrick66
    @coololdcars - A '46 ***le won't do any good for a '49 - totally different car, plus it's ILLEGAL! Ever consider the reasons why you cannot advertise for the so-called "historical do***ents" on the HAMB anymore???
    @whiskeymakin' - If the car has the original engine, you will see the vehicle number also stamped on the p***enger side of the block. It will be on the very front of the left side, stamped on a machined pad. Both of my '53 Hornets were like that, as well as a '53 Wasp I owned. I'm pretty sure my '50 Commodore 6 was, too.
  13. whiskeymakin
    whiskeymakin
    from mid tn
    wish i had the original motor, but its a mopar 318 in it now....
    the rear axle has no numbers, i can see where the plate was riveted in the door opening, not there tho.
    looked the frame over and havnt seen any sign of numbers
  14. 55 dude
    55 dude
    Contact the national Hudson ***.
  15. PacaRacer50
    PacaRacer50
    Hudson stamped a VIN into the top p***engers side of the front frame rail behind the upper control arm of the front suspension, but its not on all of
    them.
    My 50 Pacemaker was stamped there but I am not sure about the 48-49's.
    It should start with 49??????? with the third number denoting its a
    Commodore 6 or 8 depending on the factory engine it was built with.
    hope this helps,
    PaceRacer50
  16. whiskeymakin
    whiskeymakin
    from mid tn
    thanks for all of the help guys. i will keep searching haha
