How do you get door handle and window crank off door panel
Discussion in 'The Hokey Ass Message Board' started by Wizard, Apr 17, 2013.
  1. Wizard
    Wizard
    I have a 61 pontiac and trying to replace rear door gl***. Tried prying and pulling off the door handle and window crank off door panel. Won't come off. Any other way to get it off. Looks straight and simple.
    wizard
  2. flatford39
    flatford39
    There is a little spring clip that you need to remove. You might be able to snag it with a needle nose pliers and pull it off. Then the handle just slides off.
  3. chaddilac
    chaddilac
    it's got one of these...
    and you need one of these....
  4. Checkerwagon
    Checkerwagon
    The handle will have a clip at the center, [FONT=verdana, geneva, helvetica]make a small hook from a piece of coat hanger or any stiff wire. Hook the tool onto the clip and pull it out.[/FONT]
  5. HOTRODPRIMER
    HOTRODPRIMER
    These are so much fun,when I did the wagon 3 went on easy,,the 4th was a PITA,,I finally found a old clip at AAG and it went on easy as pie. HRP
  6. Wizard
    Wizard
    Thanks guys. Will give it a try.
    wizard
  7. 325w
    325w
    Red shop towel drug behind the crank base works sometimes. You have to get between the plastic washer and the crank? If using a hook watch out if you slip you can mess up a good door pad. Don't ask me how I know..!!!!!!
  8. Hotrodhog
    Hotrodhog
    I make a small hook out of a 060 welding rod....works great!!
  9. Sin7
    Sin7
    from Wylie TX
    works for me every time !
  10. atomickustom
    atomickustom
    Don't lose those clips! As hotrodprimer hinted, the new replacement clips ****. They are not quite the same shape as the originals and consequently are harder to work with.
    Thanks for the hook idea, Checkerwagon. I've got one interior door handle I can't get off (upholsterer did something screwy, my tool won't catch the clip no matter how hard I try) but I think with a small wire hook I should be able to get to the clip.
  11. Dexter The Dog
    Dexter The Dog
    a putty knife pushed behind there will work also. the clips are usually snapped in from the far side, towards the crank so get the knife under the handle.
  12. autobodyed
    autobodyed
    from shelton ct
    we used to call those jesus clips. oldtimers know why. ;)
  13. Hdonlybob
    Hdonlybob
    Amen to that !! :D
