Simple picture re-sizing
Discussion in 'Questions & Suggestions' started by HOTRODPRIMER, Jan 12, 2008.
  1. pyrojoe667
    pyrojoe667
    practice resize
  2. russell1955
    russell1955
    from Ohio
    Pences
  3. russell1955
    russell1955
    from Ohio
  4. russell1955
    russell1955
    from Ohio
  5. Sledge
    Sledge
    from Nor Cal
    test[​IMG]
  6. HOTFR8
    HOTFR8
  7. HOTFR8
    HOTFR8
    Test. Ryan, All appears OK. :) Edit, Quote and Post. :)
  8. jay7262
    jay7262
    What size do you go with, I tried 50% and still huge, gonna try 75%, have you tried to custom size by pixels?
  9. AngleDrive
    AngleDrive
    from Florida
  10. AngleDrive
    AngleDrive
    from Florida
  11. Resizing as a percentage takes a bit of experimenting. Or you need to know the original images's dimensions, the size you want to resize it to, and then you have to do a little math to figure the percentage desired. :eek:
    It seems easier to me to do a custom resize to specific pixel dimensions, if that's an option. For display in a forum post 640x480 pixels is usually big enough. The pixel dimensions are stated as width x height in pixels.
    Most image resizing tools will let you enter both the desired width and height dimensions. But often times if you set only one dimension it will automatically set the other. Just make sure to look for an option that says something like "maintain aspect ratio" or "keep width to height proportion same as original image" and click the check box to do so. This should keep your pictures from being distorted vertically or horizontally. :D
  12. hackehp
    hackehp
    from sweden
  13. this is a test
  14. westoreshop
    westoreshop
    from sfgsdgsdfg
  15. LanewayKustomz
    LanewayKustomz
  16. LanewayKustomz
    LanewayKustomz
  17. try
  18. speedy383
    speedy383
    test[​IMG][/URL][/IMG]
  19. speedy383
    speedy383
  20. speedy383
    speedy383
  21. Cruiser
    Cruiser
  22. test
    [​IMG][/URL][/IMG]
  23. RugRider
    RugRider
    from Denver
  24. Lone Star Mopar
    Lone Star Mopar
  25. Thanks a bunch, piece a cake!
