Convince me to build my 241 Hemi & quit looking for a 270
Discussion in 'The Hokey Ass Message Board' started by brigrat, Dec 23, 2008.
  1. Squablow
    Squablow
    Couldn't you just use the 241 heads on a 270 poly block? 270 Poly engines are all over the place, you should be able to pick one up cheap. Get a 55 or 56 Dodge (56 Coronet only) car with the Poly in it, keep the motor and part the rest out. There's lots of rusty 4 doors out there that could be had off of eBay for $500 or less and they part out well.
  2. J Man
    J Man
    from Angola, IN
    doesn't the 241 and 270 use the same block? The 260 Poly as well?
  3. George
    George
    Pretty much, need to check push rod clearance when using a Poly block.
  4. VonDust
    VonDust
    Good info.
    How are the Desoto 291's? My '55 Desoto has the original one, never been pulled and I've put about 35,000 miles on it in the past 5 years. Its a tough old bird and it keeps on going. But it is hard to find speed parts whereas the 291 is a one year base, no other heads or intakes will cross over. I mean, can you get some power out of the 291's? Here in about a month or two, I'll be puting a T-5 in it and it should help the power transfer. The powerflite is a slushbox and makes it a dog.
    Thanks.
  5. Lucky667
    Lucky667
    from TX
    What CAR are you putting the Hemi in? If you keep the 241 contact TR Waters(posted above), he sells the offset key you need to put the late 318/360 damper on your 241 crank. Hot Heads still advertises an aluminum 3x2 manifold for the 241-270 low deck. I'd take the 241 apart and inspect it, make sure it's right! At the very least, I would clean everything, use new bearings, timing chain, etc.
    Good Luck!
    Lucky667
    God Bless our Troops,... Especially the Snipers.
  6. George
    George
    It's a low deck like the 276. 4 bl intakes are scarce & expensive & yes very little speed equipment vs Dodge & Chrysler. Regrind cam shafts & aftermarket log intakes are about it. Check ScooterMcRad's hemi tech index.
  7. If I was in your shoes I'd build the 241 Hemi....not because of any real prefrence but because you have three!! You have spare parts and as stated above unless your going to go racing,and all your really looking for is the look in your rod, then use what you got.
  8. FAT-245
    FAT-245
    any HEMI is a good HEMI!
  9. RatrodKevin
    RatrodKevin
    kinda new just joined the h.a.m.b today. I got a 1953 241 hemi (going on a 29 A)was in a barn for like 30 yrs a block away from my home.Its geting rebuilt as we speak.It came with a factory 4bbl intake cast #1537723-1 date 5-15-55 i think its from a 270.It looks like it fits the 241?can anybody let me now if im rite and if it works with the 241? pleas im going crazy so i joined the h.a.m.b. thanx...... also do 270 valves work on the 241 thanx again....... kevo-
  10. oddcraig
    oddcraig
    If you build it they will run....
  11. George
    George
    yes
  12. 73RR
    73RR
    Hhhhmmmm.......same post in 3 places... obviously a fng.....
    Note to rrk, this will not make you lots of friends...:cool:
