31 chevy coupe front end
Discussion in 'The Hokey Ass Message Board' started by yellowbeard, Apr 18, 2013.
  1. yellowbeard
    yellowbeard
    Ok, I can use a S-10 rear end. But, what do I use to change the hubs to a 5 bolt pattern on the front? thanks Joe
  2. yellowbeard
    yellowbeard
    thanks for the info. nice setup. If I wanted to use drums, is there something out there? Thanks Joe
  3. snelson57
    snelson57
    I am converting my 29 to drums from a 49-54 chevy p*** car.
    Go to DroppedAxles.com...under chevy axles he list some good dimensional information for reference on axle and kingpin dimensions.
    I don't have all the info put in one place to help you out and it has been a while since I researched it, but do a search here on the Hamb and you will find the info that you need.
  4. hellerlj
    hellerlj
    from Minnesota
    There are many "Tube" axles with ends on them to take 49-52 Chevy Spindles...MAS in Minneapolis sold bunches of them years ago, I have a 4" dropped one on the the front
    end of a 32 Chevy Frame...I think Speedway might even sell one
  5. 24riverview
    24riverview
    53-54 brakes are a bolt on. Need to use the early inner race on inner bearing and some spacers need to made for backing plate. If I remember correctly there is a spacer on the bottom of the 54 setup it goes to the top and longer spacer made for the bottom but it's been 35 years since I've messed with this.
