stainless bolts or not on an FE exhaust?
Discussion in 'The Hokey Ass Message Board' started by greg, Apr 19, 2013.
  1. greg
    greg
    ***le says it.
    Im worried about stainless bolts galling over time. I will use anti-seize on whichever I use.
    Im not sure if one anti-seize is better than another for the exhaust heat.
    Also planning to use just red rtv without gaskets since i had both surfaces milled. There is one small place that didnt quite mill out on the manifold that does have me a little concerned.:confused:
    also, does anyone know where to get the star bolt locks that are like the factory used?
    Thanks, Greg
  2. loveoftiki
    loveoftiki
    from Livonia,Mi
    It's an FE it will leak ha-ha
  3. FAST57F100
    FAST57F100
    from Washington
    I have used the stainless bolts on my Ford exhaust manifolds for years and have never had an issue with removing them.
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    We've been using antiseize on all the stainless fasteners we use, including on exhaust parts. It has something like a 1600 degree rating so it is pretty much still there when you remove the bolts later on.
    Don
  5. osidebarrel
    osidebarrel
    from San Diego
    I tried a lot of different gaskets that all leaked before I surfaced the heads and manifolds of my FE and sealed them with RTV, no leaks now
  6. greg
    greg
    Thanks,
    is the regular old silver anti seize good enough?
  7. Special Ed
    Special Ed
    I have used stainless bolts on my 1966 FE with regular old silver anti-seize for the past twenty years or so. No problems to report ... :)
  8. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yep, just the regular old Permatex (I think) or similar brand antiseize will do te trick. Brush on a nice heavy coat and you should have no problem getting them back out ever. I do find I have to retorque my header flange bolts occasionally, but those always loosened up anyway, no matter what bolts I used.
    Don
  9. chevyfordman
    chevyfordman
    The p*** side rear bolts always seized on me so once I put stainless bolts in with the silver anti-seize, there was never another problem for 25 years now. I did have to check the bolts for a few years as they did back out once in awhile, but that's it.
  10. fairlane 63
    fairlane 63
    from NO.DAK.
    Try mcmaster carr for the washers
  11. greg
    greg
    Thanks all, I found a place called " greg donahue" from florida that list the locking washers. and Mcmaster carr will have the stainless bolts.
  12. supervert
    supervert
    I used new stainless bolts and split washers and copper anti seize with remflex gaskets on my wife's 352. Works great, no more leaks and the nature of the gasket, they don't loosen. We just tore apart my brother 302 that had the same setup and the gasket were still nice and soft after thousands of miles and never came loose.
  13. Yo Baby
    Yo Baby
    If you've got the holes prepped,use studs & nuts.
  14. earlymopar
    earlymopar
    It depends on what series and alloy of Stainless you have in the bolts in question. In reality, if you compare stainless bolts to regular carbon steel bolts that are of equal hardness, the stainless will have much less tendency to gall due to the nickel in the stainless with offers a slight bit of lubricity. You likely have 300 series bolts (302, 304, etc.).
    - EM
  15. Ford blue blood
    Ford blue blood
    I salvaged two tubes of anti seize from "uncle sugar" many years ago. Used in the steam plants aboard carriers (1200 psi, 1350 degrees steam) that has done the trick for years. It is gray in color and is most dificult to get out of your finger prints. All the FEs that I have run have never had gaskets (use cast iron manifolds), surfaced the manifold, verified the head and used anti seize on the surface as well as on the ss bolts with standard ol lock washes (ss too). No re-tightening required.
