Need Help with 1934 Ford 5 Window
Discussion in 'The Hokey Ass Message Board' started by dhwms, Mar 29, 2013.
  1. dhwms
    dhwms
    from Tennessee
    I am working in the trunk area with the placement of the inner panels. There is a inner panel sold by several parts vendors that I do not have and worse yet, I do not know where it fits. I am going to try and attach a picture of the panel that I am confused about. Thanks for your help. A picture to me is worth 10,000 words.
  2. alchemy
    alchemy
    You have the pic the right way up. It goes inside the panel below the trunk. Bolts (rivets?) down to the top of the floor.
    That part is left out of a lot of hot rod builds. I'd think it would add strength and should be installed.
  3. ss34coupe
    ss34coupe
    It would help to see some pictures of the trunk area of your coupe - but presuming it is all stock and you have the original floor, then this panel
    bolts to each side at the bottom of the quarter panel. You will see three
    holes on the inside portion of the quarter panel. The panel that fits below the trunk lid - with the pictured panel inside it - will bolt to the quarter panels.
    If you can take some pictures and post them that would be great. Besides, we would like to see you car anyways!
  4. ss34coupe
    ss34coupe
    Here is a pic of my coupe where you can see the panel below the trunk lid. The piece you have pictured fits inside that panel.
  5. dhwms
    dhwms
    from Tennessee
    Thanks Alchemy and SS 34 Coupe. Your answers are great and confirm my thoughts. I was concerned about the panel below the trunk lid and the floor pan holding the rear of the body together. I am in the process of replacing the two rear pieces of the floor pan. I am trying to keep the body the way Henry designed and built it.
  6. dhwms
    dhwms
    from Tennessee
    I purchased the panel from Howell's and well pleased with the product and service.
    Now for the dumb question. How does the rain gutter dispose of the water ? It appears that the water will be dumped into the trunk.....
  7. fordcpe
    fordcpe
    If it is rumble seat water goes in the trunk and drains out holes in floor without rumble it still does this but lots sits in the trough at the back do yourself a favor and make some drain tubes.
  8. dhwms
    dhwms
    from Tennessee
    Thanks for the reply. I was thinking about the drain tubes. I ***ume that you have drain tubes .Do you have any pictures of your tubes?
    Thanks
  9. fordcpe
    fordcpe
    Sorry mine is rumble different then trunk
  10. dhwms
    dhwms
    from Tennessee
  11. millersgarage
    millersgarage
    maybe this shot will help. The water collects on the floor, and drains out thru the hole. The dam that runs across the floor is there to direct the flow..
  12. dhwms
    dhwms
    from Tennessee
    Thanks for the picture.
