Does anyone still work on buickdynaflow trans in the srvierville t,n area?
Discussion in 'The Hokey Ass Message Board' started by Bruce Fischer, Jan 8, 2013.
  1. I still have the 1956 buick special station wagon and wondered if any one still worked on buick dynaflow transmissions in this area?.I think mine has a front seal leaking and am not sure how to pull out the transmission.Any help would be greatful. I am in Sevierville.T.N.37876.Bruce.:cool:
  2. HOTRODPRIMER
    HOTRODPRIMER
  3. Hi Guys got my brake booster rebuilt and back in about 8 days.Got it in stalled and bled the entire system.Decide to try and take my 1956 buick station wagon for its 1st test drive since i bought it about 6 months ago.Now the trans still leaks but i want to see if she shifted and just need a gasket kit.Mind you she was in storage for the past 20 years.I chuged down my mountian top drive way and took it down to the local E**on station for gas.Well she shifted well but the ride was a little schey with the 20 year dry rotted tires.lol.After paying for the gas,There were quite a few people around it wanted to know what kind and year it was.I pulled out and was trailing transmissiom fluid like a wounded worrior.lol.The trip was about 5 miles and i was almost home when the water pump started howling and the temp shot up.I made it up our mountian top drive way just as she starting getting hot.I let her cool down for about 3 hours then flushed the entire cooling system but the water pump still was howling.E bay has 1 for about $140. Rock auto just rebuilds then.I am going to see if my local Nappa store can help me .I will keep you all posted.Thanks Bruce.:cool:
  4. oldwood
    oldwood
    from arkansas
    The fun of buying an old car. Now it is time to roll up your sleves and get to work. Please post pics.
  5. 53catalina400
    53catalina400
    from Mebane,NC
    at least you got to drive here pull that dynaflow out and put a seal in it ur self or send it to me in nc and ill do it for you for free might be worth it i dont know how much ur tow would be for a four hour ride one way?water pump is no problem napa should have it or order a reman for 150. hope you get her right
    i still have to rebuild my booster or retro fit a new style above the steering gear
  6. 40Standard
    40Standard
    from Indy
    let's see some pics of the ole girl. you should probably start going thru the wagon, new hoses, tires, brakes ect to make it a safe ride. good luck
  7. I will post so picture of her if someone can explain how to do it on here.Thanks Bruce.:cool:
