36 chev grille help
Discussion in 'The Hokey Ass Message Board' started by 4fingeredwill, Apr 21, 2013.
  1. 4fingeredwill
    4fingeredwill
    Hey all, we are trying to figure out to get the grille mesh stuff out of the radiator surround housing thingy (all very technical terms). When we turn the bolts they just spin and there is nothing on the other side? It's a friggin enigma? Is there a trick we don't know about or should I just cut them off?
  2. Ghost28
    Ghost28
    You might have to cut them off and replace them, but If you can bend a cheap small screw driver to lodge aganst the back piece it wil some times jamb and you can get the nut loosened. I usually have to cut them loose carefully.
  3. skippycraig
    skippycraig
    from Washington
    Went thru the same trouble, ended up cutting them off and put new bolts in.
    Sent from my DROID device using the TJJ mobile app
  4. 4fingeredwill
    4fingeredwill
    thanks guys, figured this was gonna end with the cutting wheel!
