440 Chrysler into 57 chev
Discussion in 'The Hokey Ass Message Board' started by wade57, Jan 16, 2013.
  1. vintagespeed
    vintagespeed
    Yup i am here.
  2. toolz1175
    toolz1175
    from IL
    It's too easy to put a B/RB in anything. Don't really need a motor plate- just 1/4" steel plate bolted to the front two motor mount holes on each side, and weld to the frame. For headers, use small block Chevy headers for the '57, and change the flange at the motor. The exhaust port spacing is real close. In fact, to make custom headers for a 440, some header companies sell you small block Chevy kits and add 440 flanges. If you do it right, the Chebby guys will be asking how you got that distributor on the front of your 350...
  3. Dane
    Dane
    from Soquel, CA
    Since every Tom, **** and Harriet has put a 350 Chevy in just about everything, I guess a 440 in Chevy will be ok. Especially when it blows the doors off all the rat motored Chevys... :D
  4. fleet-master
    fleet-master
    certainly have more power than THIS conversion..!! :p:D:D:eek:
  5. fleet-master
    fleet-master
    ****, now thats good info...makes perfect sense!
  6. mrdodge
    mrdodge
    I had a mate with a big block Chev in a 57 Mercury......DO IT !!!!!:D
  7. jcmarz
    jcmarz
    from Chino, Ca
  8. 296moon
    296moon
    from england
    Ive put a 440 in my Ranchero, have I made a Fopar?
    Clay Belt likes this.
  9. zep058
    zep058
    ^^^Boom, tish! Hahaha
  10. theHIGHLANDER
    theHIGHLANDER
    And my pals thought I was crazy wanting to put a BBC in an altered WB 64 Barracuda...
  11. moefuzz
    moefuzz
    Cool!
    The engine GM wishes they could have designed and built (especially after loosing year after year in every form of racing)
    Go Mopar!
  12. moefuzz
    moefuzz
    People that own 57 chitvies can read?
  13. roddin-shack
    roddin-shack
    Several years ago I put a 63 Dodge H.P. 383, in a 55 Chev 2 door including the Torqueflite Trans. and the original push****ons mounted in the dash. Believe me it was a great combo and it had very little compe***ion on the streets. GOOD LUCK, you will be sure to surprise a lot of people. Larry :cool: :cool: :cool:
  14. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    I've got a few friends that are Mopar guys, and between them, there are a few engines lying around. Not sure about any 440s, but I do know one guy has a running 383. Would that be worth the effort? What kind of power can you make with those?
  15. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    Answered that question!! :D
  16. 73RR
    73RR
    So, what is the plan? Time to let us know!
  17. black 62
    black 62
    from arkansas
  18. foolthrottle
    foolthrottle
    rear sump truck pan,truck or motor home motor mounts up to 1979, should be easy.
  19. InstantT
    InstantT
    from SoCal
    Almost as bad as BBC guys feel when an SBC blows their doors off (which is more common than I ever would have guessed)
  20. ZAPPER68
    ZAPPER68
    from BC
    Back in the day a couple of us put a 392 Hemi in a '57 Chev sedan delivery. We kind of screwed up on the engine mounts and couldn't get the hood to close....and in about 1980 or so I put a 396 BBC in my 56 F100. That was an easy swap and the turbo 400 combined with a 9" from a 67 Mustang was a cool ride.
  21. toolz1175
    toolz1175
    from IL
    The 383 is a rock solid engine- short stroke, revs good, but the 400 is even better. Both have a shorter deck than a 440, so will fit stuff easier. The 400 actually has a bigger bore than a 440. Bore it another .030, turn down a 440 crank for it (smaller mains) and you get a 451 that is almost as light as a 350 chebby.
  22. Agreed except the weight thing - all iron big block mopar is like 700 lbs (deep skirted block, lots of iron)
  23. 73RR
    73RR
    Who cares about an extra 100lbs when you have the grunt on tap ?
    The 451 has to be one of the best and cheapest mods of all time. Need more inches? Plenty of 4" cranks available...and most folks will have no clue as to how to get their car to hook up at that point.:eek:
  24. chryco
    chryco
    from Winnipeg
    Go For It ! A Blower Would Be NICE too !!!!!!
    Bighead440 likes this.
  25. Dane
    Dane
    from Soquel, CA
    A hot 383 is nothing like a hot 440. The 440 will squench your ****... :D
  26. SloppyEggs
    SloppyEggs
    I ran a 451 in my 68 Barracuda that I had in high school, and I'll tell you what... That thing would make you pucker up where you sit when you mashed the skinny peddle! Back to the topic at hand though, I love the idea of sticking a mopar engine in a chevy! It's like ***** **** - So dirty yet so exciting!
    This was the beast from my teen years...:D
  27. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    Few things more satisfying. :D
  28. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    I gotta say telling people I have a 383 under the hood will be fun, since it's a common SBC stroker. :D
  29. patrick66
    patrick66
    Put that 440 in that '57!!! I get so tired of seeing Chevy belly-****on engines in nearly everything, that turnabout is fair play. Plus, that Chevy will go faster with the Chrysler lump than if it had a SBC in it. It's all about being innovative and different. Chevy engines are not different.
    Need video of this when you fire it up!!!
