Help with Hemi deck height
Discussion in 'The Hokey Ass Message Board' started by Rob3865, Mar 28, 2013.
  1. Rob3865
    Rob3865
    I have a '56 331 Hemi. I have the block in the machine shop now. The figures I have found for deck height says the 331 should be 10.320". My machinist called me today to let me know that the block sits now at about 10.385". That seems awfully tall. All I want is to blueprint the deck height to the correct stock spec and nothing more. I know Chrysler was sloppy with deck heights, but is this much normal? Please let me know if my deck height spec is correct. I think it's right because I've pretty much found it everywhere.....including here in another area. I appreciate any help. Thanks.
    Rob
  2. turdytoo
    turdytoo
    Check the stamped number on the front of the block and cross to application. I have been told some truck hemis are unique.
  3. Rob3865
    Rob3865
    I was just lucky enough to catch Bob Walker hisself at Hot Heads. He says the deck height is correct at 10.385, so all I am going to have done is have it squared up. I am glad that I didn't go ahead and knock .065" off. The only number anywhere on the net is 10.320. I'm sure it's right for some things, but evidently not this.
    Btw, it does happen to be a truck engine.
  4. TR Waters
    TR Waters
    from Vermont
    There is nothing different as far as deck height with truck engines.
  5. Rob3865
    Rob3865
    Ok. So which number is correct? I would like to think Bob Walker would know. He said "10.385" before I had a chance to tell him what mine measured. Does that mean all the info that says 10.320 is wrong?
  6. 73RR
    73RR
    A recently measured 54-331 was 10.308".....
  7. Rob3865
    Rob3865
    Then they must be all over the place. That's crazy.
  8. TR Waters
    TR Waters
    from Vermont
    My last 331 was squared up at 10.370. You need to have yours decked (trued)... then essentially it is what it is. Then order pistons accordingly.
  9. 73RR
    73RR
    ^^^Thats the way we deal with them; the number is just a number.
  10. Rob3865
    Rob3865
    Well, I just called him back and told him to square it up where it is. I already have pistons. I got the Egge 55 331 stock replacements. Mr. Waters was kind enough to give me a good deal on some thin Fitzgerald head gaskets, plus, I am having the heads milled .025". It will be what it will be. In the end, I'll probably be dang happy because it will likely run on 87 swill. Thanks yall. Yall are always helpful.
  11. 73RR
    73RR
    When you get the shortblock ***embled do a downfill check and let us know what you find, and also cc the heads after you cut them.
  12. Rob3865
    Rob3865
    I will. It may be some time though. My wife lost her job on Valentine's day and today is my last day here, so our budget is taking a hit. I guess you're talking about doing a .500" downfill measurement? If not, let me know what you are referring to and I will do it.
  13. Rob3865
    Rob3865
    I was able to get the long block ***embled. Here it is in all its blueness. I know it's not an original Hemi color but I love Chrysler blue. It ended being 9.16:1 on compression. I am happy with that.
      75.8 KB
      88.6 KB
  14. afaulk
    afaulk
    Dang....thats a lot of blue paint. Me like!
  15. ago
    ago
    from pgh. pa.
    What is with the timing chain tensioner, never seen that on an early Hemi?
    Ago
  16. Rob3865
    Rob3865
    That's from any 3.9 Mopar V6 and some 5.2 and 5.9 later Mopar small blocks. It's a very simple fit on the early Hemi. Since the camshaft hole and one hole already line up, all you have to do is drill three more in line with the other three on the stock cam thrust plate. There are also two oil galleries in the front that are exposed that are normally blocked by the stock thrust plate. I simply found the correct size freeze plugs and knocked them in, then installed the tensioner. You also need to dress the two dimples in the tensioner so the bolts will pull it down evenly in the front. There's really nothing to it. Lastly, just like on a small block, I drilled a hole all the way through the top retaining bolt on the p***enger's side. This allows oil from the intake valley to run right on the oil diverter on the tensioner and fall directly onto the crank gear and timing chain.
  17. TR Waters
    TR Waters
    from Vermont
  18. Rob3865
    Rob3865
    Thanks, Mr. Waters. That means a lot comin from you.
  19. Rob3865
    Rob3865
    I painted the heads and set everything back on it including the wire covers.
      78.6 KB
      77.1 KB
  20. BashingTin
    BashingTin
    Looks fantastic Rob!
  21. fridaynitedrags
    fridaynitedrags
    The Ford Lima motor, 429 & 460, was 10.300" from '68-'71. Maybe someone posting on the web got the Ford and the early hemi confused.
  22. TR Waters
    TR Waters
    from Vermont
    Not to hijack, but here is a tensioner that I modified for an early hemi.
  23. chryco
    chryco
    from Winnipeg
    Better check the fit on the intake . That angle will change when the deck and or the heads are milled
  24. Rob3865
    Rob3865
    I already have. It's fine.
    ...and Mr. Waters, you are where I got the idea from. I actually emailed you looking for one, but you said at the time that you didn't have any, so I just winged it.
  25. Rob3865
    Rob3865
    I wonder that myself. Google it. I came up with 10.320 everywhere. Even The Victory Library. I know there are mistakes in everything, but I'm tellin you 10.320 is everywhere as the early low deck Chrysler deck height. I sure am glad I consulted here and called Bob Walker. I don't think it would have ruined it, but I certainly would have had to mill the intake too.
