Projects My First Custom - Shoebox Project
Discussion in 'The Hokey Ass Message Board' started by the-rodster, Aug 26, 2010.
  1. the-rodster
    the-rodster
    Cutting and fitting the stainless....
  2. the-rodster
    the-rodster
    Welding, sanding, polishing, etc....
  3. the-rodster
    the-rodster
  4. the-rodster
    the-rodster
    Let's not forget the garnish.
    Weld, sand, paint, etc....
  5. EBW
    EBW
    Damn, that is nice !! I hope I can get mine to look like that.
  6. ausbuick
    ausbuick
    very neat work on the window trim buddy.
    Cheers Darren
  7. the-rodster
    the-rodster
    That's a good question.
    I'm adapting the system used on wire wheel covers of full size cadillacs of the 70's and 80's.
    They used a hub that mounted under the lug nuts that the wheel cover could be bolted to.
    I'll try to dig up some pics.
    Rich
  8. 5.0inthe610
    5.0inthe610
    Just read these 20 pages... This is amazing... Good work.
    subscribed
  9. SoCal
    SoCal
    Thanks man. Would love to see them.
  10. Buddy Palumbo
    Buddy Palumbo
    The stainless & garnish moldings turned out great - nice work !
  11. tedley
    tedley
    from canada
    Man that's finiky stuff welding the moldings. Very very nice.:)
  12. 4rod
    4rod
    Looks great cant wait till I chop mine all the little stuff is tedious though. My dash is finished just waiting for wire harness from rebel so I can wire it up outside the car. Nothing more frustrating them wiring on your back
  13. LeClaire
    LeClaire
    from Minnesota
    Looks amazing!
  14. manyolcars
    manyolcars
    For the benefit of those who look at these threads to learn how to do things, be aware that silicone sealer has an acid that attacks metal. Use Urethane to seal the windows
  15. the-rodster
    the-rodster
    I think that there are acidic and non-acidic forms of silicone.
    This is from the instructions....
    "Suggested applications include windshields, door frames, electrical connections, seams and roofs, vinyl tops, and weather stripping."
    But, yeah, when it comes time for sealing the entire windshield, I would go with urethane.
    Rich
  16. captaintaytay
    captaintaytay
    Any progress on the build?
    Like the work your doing.
  17. the-rodster
    the-rodster
    It's pretty slow going, project-wise, during the summer months.
    I did get the brakes bled, last of the gl*** in, getting ready to fire the engine for the first time.
    Checked compression on all the cylinders, all at 185 - 190, installed the distributor, etc.
    Rich
  18. captaintaytay
    captaintaytay
    Is it slow because of hot weather in KY in summer or?
    Looking forward to see finish.
    Nice fab work, it's helping me also, Thanks
    Kevin
  19. the-rodster
    the-rodster
    Nope.
    It's because I spend most weekends on the lake drinking beer.
    If not the lake, then at a car show.....drinking beer.
    During the winter, I build cars, and drink beer.
    Rich
    gearheadwelder likes this.
  20. captaintaytay
    captaintaytay
    LOL, I like that, sounds like a great system:)
  21. EBW
    EBW
    I like your system and will gladly copy it!!!!
    Here's to summer.
  22. Barn Hunter
    Barn Hunter
    Great attention to detail on the trim. Roof profile, stance and wheel/tire combo look awesome. Will be following. Have you got some colors in mind for exterior/interior?:)
  23. Blacklisted
    Blacklisted
    I like the way you roll! Great job on the car, great attention to detail, fab work. I wish I had 1/10th of your skill.
  24. junkyard junky
    junkyard junky
    Looking good! I think I need to sell you another car or two. You never can have too many projects going on.:D
  25. b-bob
    b-bob
    This series of articles should be followed by a lot of beginners who are wanting to learn how to do these things and so they can see how much work goes on that doesn't show on the outside.
    This shows how much time and patience is required to build a quality, safe, reliable project. It takes longer and takes more patience than a lot of people realize.
  26. ClassicDriver
    ClassicDriver
  27. the-rodster
    the-rodster
    OK, summer is winding down.
    Time to get back in the garage.
    I needed to build a ****** tunnel, the car didn't come with one, and a stock one probably wouldn't fit the 700r4.
    I first made a paper template.
    Then I fabbed one up.
    It turned out nice.
  28. the-rodster
    the-rodster
    Next, I fitted the radiator.
    I spaced it forward about 1/4 of an inch.
    It just clears the steering pump, and gives about 3/4 inch clearance to the fan.
  29. the-rodster
    the-rodster
    Running the ****** cooling lines took longer than I want to admit.
