Something different for small block Fords
Discussion in 'The Hokey Ass Message Board' started by Henry Floored, Apr 25, 2013.
  1. Henry Floored
    Henry Floored
    Below are a few pics of a project that started in my mind about 20 years ago. It was an effort to change the outward profile of SBF's with regards to early car swaps. I wanted to design a system that removed all the perceived problems with swapping front oil pumped SBF's into mainly early Fords with transverse spring front suspension. There is an interference problem with oil pump to crossmember clearance in stock frames/ch***is mainly with `35- `40 Fords. Today the easier solution is simply modifying the crossmember by moving it down slightly and using a de-arched spring to maintain proper ride height. Back then I was trying to remove the excuses that people used as reasons why some form of brand x engine was used to repower their early Ford.
    This is a crank driven Gerotor oil pump, integral with the front timing cover. It eliminates the stock oil pump, driveshaft and front sump/bump oil pan. I don't have any video of it running because at the time I did not have a digital camera or video machine. I did have it running and it performed very well. A few individuals with an interest in early hot rods at Ford Motorsports (called that at the time) were quite interested in the outcome of this thing. Unfortunately I was not able to secure enough funds to bring this to fruition.
    One might notice that the current V8's coming out of Detroit employ a similar oil pump configuration. I got the idea while thinking of the front pump ***embly in an automatic transmission and the crank driven P/S pumps of the mid 60's Lincolns. This was an attempt to meld the two together to pump engine oil and thereby creating an even more compact and tidy profile for the small block Ford.
    So here we go with some pics.
    prototype of ***embly front view
    and from the inside
    from the front cover off
    close up of gears
    exploded view
    drive hub
    gear on hub
    fairly good packaging
    ***embly
    pickup and delivery plumbing
    all together
  2. Henry Floored
    Henry Floored
    May I say that I had plenty of help from a person with real engineering background. It certainly would not have been possible without him. I learned much and was a attentive student of his during the process of conception to working prototype. Great experience!
  3. Hnstray
    Hnstray
    from Quincy, IL
    Neat piece!........Congratulations on your 'thinking skills' and determination to make it work.
    Ray
  4. Heo2
    Heo2
    i like the idea very nice thinking
  5. MBog
    MBog
    Nice! Any pics with it installed? What kind of pressure does it supply?
  6. Henry Floored
    Henry Floored
    I think I have one or two scans of small photos of it all installed on my test engine. I gotta dig around for them. As far as supply pressure goes we had it arranged to be adjustable on the prototype. I think we dialed 20lbs hot at idle and only tested up to about 3500 rpm with the engine freewheeling. Never did get it on a true dyno. If memory serves me correctly she went right up to 50lbs + at speed. Final pumping pressures and volume was one of the expensive steps to be learned in dyno testing. I came close a couple times with interested parties but never could tie the knot.
  7. Very cool idea. Thanks for sharing!
  8. JEM
    JEM
    Wow. Very nice work.
    The first engine I ever laid hands on with a snout-mounted gerotor pump was the 1981 Saab B201. I'm sure it must have been done somewhere before that, and it's certainly very common now. Of course, it didn't help that Saab in those days (and the next decade thereafter...) was using an elastomer in their dampers that de-bonded at the first whiff of oil, so a little spill, a leaky cam-cover gasket or oil filter seal, and the ring would start to work its way in and grind the heads off the oil-pump mounting bolts...the engines were in the car backward, with the damper at the back, so any oil anywhere would end up on the damper...
  9. hotroddon
    hotroddon
    Interesting idea. Years ago I solved the dilemma with a Moroso Dry Sump pump but ran it to a rear sump pan - worked great.
  10. Phil1934
    Phil1934
  11. Zerk
    Zerk
    This would be an ideal setup for a crate motor.
  12. hotroddon
    hotroddon
  13. Henry Floored
    Henry Floored
    Wow! thanks Phil that's incredible. So cool to see the concept in finished form. I'm gonna have to check that out. Thankyou very much!
  14. fiftyv8
    fiftyv8
    from CO & WA
    Well done, great innovation.
    <HR cl***=full>
  15. falcongeorge
    falcongeorge
    from BC
    Just the other night I was looking at photos of a real nice '36 Ford coupe in a mid-seventies street rodder that used a single stage weaver pump. Neat idea, cool thread. When I was opening it, I half-expected to see Y-block valve cover adapters or something silly, glad I took a look.
