Projects the '27 Roadster saga
Discussion in 'The Hokey Ass Message Board' started by Paul, Jul 20, 2010.
  1. LB+1
    LB+1
    from 71291
    Wow on the air factor!
  2. captainjunk#2
    captainjunk#2
    i like the build , the little plane looks great on the radiatorcap to ,
  3. ..like the way you are writing and working on that, Paul! done good, i stay subscribed. ;)
  4. h.i.
    h.i.
    from denver
    Love that little roadster! I like your work a lot. Amazing stuff.
  5. I totally checked out that blown RPU in the lot as I was going in at the corvette swap this saturday, then I saw you driving it. That thing is awesome. :)
  6. Paul
    Paul
    Editor
    That was a pretty good swap meet, I scored a 2x4 manifold and aluminum valve covers for an Olds and a pair of old AFBs cheap
  7. iammarvin
    iammarvin
    from Tulare, Ca
    Paul, could you post up some pictures of how you mounted the brake and clutch master cylinders? How is it braced on the firewall?
  8. attitudor
    attitudor
    from Finland
    Cool machinery you got there! Dig the McGulloch!
    --mika
  9. Paul
    Paul
    Editor
    right now it's just the Ansen swing pedal setup on the back side, may go with below floor pedals but if I do go with the Ansen setup it will get well braced
    thanks Mika!
  10. What a great profile! I really like how it sits. Being Olds powered is even better :D
  11. That's a good looking fleet!
  12. fordman1
    fordman1
    Any updates? Great builds!
  13. Paul, is that mounting bracket for the Paxton actually designed for the Olds? Or another that's been modified?
    Reason I ask is I have a SN60 of a friend's here that he intended to mount into his Olds (1952 88 convertible) but the bracket and tensioner are supposedly for small block chev.
    I've even been toying with the idea of mounting it onto a Windsor if I can get the right bracketry, which from a quick bit of research, shows the bracket for them are available.
  14. Paul
    Paul
    Editor
    sadly, nothing to report right now
    no excuse is good enough but what little time I've had after work and other of life's adventures I've spent on other things in the shop.
    I was putting together a list of to do's in my head yesterday and if I was like some of the fast builders on this site it could be on the road in a week,
    me, it might take another year or two..:rolleyes:
    it's a McCulloch, pre Paxton, and yes it is Olds specific..
  15. Jkustom
    Jkustom
    You're a hero Paul. Keep up the good work.
    Paul likes this.
  16. Paul
    Paul
    Editor
    short block ready for heads to go on
    had a cam cleaned up a while ago, so long ago I couldn't remember which one it was
    took it back to Delta and Ken pulled up and printed out a new data sheet
    it's a 282S grind, this one should have some attitude :)
    oliver westlund and brEad like this.
  17. LB+1
    LB+1
    from 71291
    dumb ass ? I guess
  18. Paul
    Paul
    Editor
    Picked up a set of solid lifters yesterday, I will make an adjustable push rod to determine correct push rod length to order.
    Cleaned up and organized most of what it will take to button it up,
    If all goes well it will be together this weekend.
    oliver westlund likes this.
  19. CGkidd
    CGkidd
    Awesome Paul
    Sent from my DROID device using the TJJ mobile app
  20. Paul
    Paul
    Editor
    sights and sound guaranteed
  21. Looking great, Paul!
    Hope I'll get my parts soon too, so I can make a startup video.
    Which you'll have to do also!
  22. TexasSpeed
    TexasSpeed
    from Texas
    Your small collection of hot rods has always been high on the list of my envy. You have too many cool toys in that garage.. Looking great, Paul.
  23. LB+1
    LB+1
    from 71291
    Thank you Sir - Car is spot on
  24. 52pig
    52pig
    Something about a freshly machined and cleaned engine just gets my heart tick-tocking...love the build.
  25. very nice Paul !
  26. Paul
    Paul
    Editor
    as it usually goes there's a minor hold up with parts,
    so in the mean time I thought I'd try my hand at the remove rust with vinegar trick
    'never done it before, so after about five minutes doing a little on line research
    I went to the local got everything grocery store and picked up a plastic tote and four gallons of distilled white vinegar
    poured the vinegar into the tote, dropped some test stuff in and let it soak overnight
    these valve covers and valley pan were cleaned and stripped and left bare for what looks like several years unprotected
    they had a moderate coating of rust
    but no grease or paint saving that step,
    vinegar will have no effect if it can't get to the rust or metal
    anyway, here's some pictures to prove it happened :)
    soaking, wire brushed and finally washed and dried
    they actually look much better in real life
    these will likely get some paint and go back on the shelf as they may not clear the adjustable rockers..
  27. Paul
    Paul
    Editor
    more busy work,
    the McCulloch still needs a few things to be ready to bolt on, if I do decide to use it
    so the engine will get a Cragar 4x2
    but the Cragar has tiny ports to match the 303 engines
    so... I took some rotary files chucked up in a drill motor to it
    and opened the ports up to match the 324 heads
    should breath a little easier now :)
  28. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Very cool Paul
    Although the McCulloch is very cool,somewhat rare and sought after....I just love the Cragar set up for the hotrod look.
    The McCulloch reminds me of some air raid siren.... ha ha
    anyways....you continue to inspire.....great stuff buddy.
  29. Paul
    Paul
    Editor
    thanks Jeff!
    yeah, I like the McCulloch too
    but I think the 4x2 fits the style of this car a little better
    I dunno, we'll see
    squirted some paint at some parts
    used some "Antique Ford Green" I had laying around
    brEad likes this.
  30. hotrd32
    hotrd32
    from WA
    Lookin forward to seeing this in person Paul ....................!
