Features Falcons done right?
Discussion in 'The Hokey Ass Message Board' started by guiseart, Nov 20, 2005.
  1. 63comet
    63comet
    I did the drop on my comet. Found a printable layout on one of the mustang sites. Glued that to a bit of aluminum, drilled big holes in the 'old' locations and holes just big enough for my center punch in the 'new' locations. Couldn't use it as a drill guide obviously but it's what I had laying around.
  2. need louvers ?
    need louvers ?
    One inch down, and 1/8" back from the stock locations. I made the upper holes a tight slip fit for the stock upper holes, and made the lowers 1/4" then up drill them in several stages until I'm done.
  3. 63comet
    63comet
    I'm pretty sure I wore out my Unidrill going through the towers, lol. By the fourth hole I couldn't keep enough oil on it I stop it smoking. Can you sharpen those things?
  4. 1971BB427
    1971BB427
    from Oregon
    Yes, you can recut the leading edge to get it sharp again, and sharpen the tip like any drill bit.
  5. 1971BB427
    1971BB427
    from Oregon
    I got my new Hurst tires today for the Falcon, and got them on. Then did some test fitting of old Mercedes front fender lip to finish up the wheelwell radius.
  6. MUNCIE
    MUNCIE
    from Houston
    Looking good, looks like you did away with the shock towers to squeeze that 390 in there.Any pictures of the bag set up on the front?
  7. 65falcon
    65falcon
    Some pics attached. Yes shock towers are gone.
    I used a stock M2 cross member and Heights lower A-arms and their upper bag mount. I had to add an outboard upper shock mount to make it work. Standard Firestone 2500 bags. have since changed the front shocks to ones with integral bump stops - yellow.
  8. need louvers ?
    need louvers ?
    Cool, good to see. If I won't sound like a total ***, I'd like to make one suggestion though. I see you went over to tube "strutless" lower arms. One of the best things you can do with that situation is to make a rear mount that captures the the lower inner pivot and ties to the frame. The strutless "A"type arms on Mustang IIs have a bad habit of tearing the rear wall of the crossmember out when that rear pivot is not mounted in double shear due to braking and suspension shock loads. By adding the bracket I'm speaking of, you remove that load from the cross member's rear wall and apply it back out to the frame rails where it went in the original Mustang II design with the strut rods. Member here ElPolacko wrote the most definitive Mustang II tech post ever many years ago and it is available with a simple search here on the H.A.M.B., and addresses this deal super easily.
    I'm not meaning to criticize your work, but I have seen this deal happen time after time between doing my own shop stuff and helping ove at El Polacko's shop over the years.
  9. need louvers ?
    need louvers ?
    Hey gang,
    I hate to sound like the town librarian again, but it's time to remind everybody that we have a huge Falcon tech thread called "Doing Falcons Right" here on the H.A.M.B. as well. It kinda behooves us to keep all the tech stuff in one place so it doesn't get dilluted and will be around forever in one spot. the original intent of this thread "Falcons DONE Right" is to display finished cars for all to see... Sorry if this ruffles some feathers, but done right we can keep both threads viable and easy to use.
  10. 65falcon
    65falcon
    Great suggestion - I see lots of value in that idea.
    Thanks
  11. MUNCIE
    MUNCIE
    from Houston
    Thanks for posting I was just curious on how it all worked together.I have a 64 and wanted to bag it a while back but over the course of the last two years I changed my mind.Took off my lowering blocks on the rear and I am now trying to squeeze in the tallest piece of rubber I can fit into my rear wells.
    Been hunting for another block to start building over the summer and into the winter with hopes of having it ready by early next spring.I didn't want to shoehorn a 351 in the small engine bay so as of now been looking for a 302 to build.
    :cool:
  12. Jeem
    Jeem
    Alliance Vendor
    Totally. Even in my RAINMAN mind, I've always thought this was a big problem in the Strut Eliminator lower arms. I can SEE it twisting every single time it takes a bump in the road.
  13. need louvers ?
    need louvers ?
    You have probably seen a good number of the cross members Steve has fixed over the years because of this deal. I have a few under my belt these days too. Just one of those deals I'm kinda picky about, and it probably comes from driving my cars as hard as I do.
  14. gimpyshotrods
    gimpyshotrods
    On the topic of strut rod bushings, of the stock-style variety: I took out my custom polyurethane ones today, and replaced them with good old rubber. It was a VAST improvement in ride comfort. The suspension actually moves now.
    Now, if I can just figure out why my brand-new, fully greased, p***enger-side upper ball joint is squeaking, I will be a happy camper. I suppose that I might be pushing the limit of the balljoint travel running this low, but why just the right side? I will probably cut-and-weld my control arms to fix the balljoint angle. I can't see spending $300 on a pair of wedges, and a pair of balljoints.
    EDIT: I found some wedges on that Internet auction site that shall not be named, for less than my time is worth to cut-and-weld my arms, so those will be installed as soon as they arrive. Might not be totally necessary, but, for my mental health, they are going in.
  15. conley customs
    conley customs
    "searchin for beaches" my over painted 63 wagon...
    Maverick Daddy likes this.
  16. bengeltiger
    bengeltiger
    Really liking the Econline headlight surrounds. Perfect!
  17. gimpyshotrods
    gimpyshotrods
    Yeah, digging those!
  18. bengeltiger
    bengeltiger
    This is my '63 Falcon. True story: I bought this last Fall (2012) from a retired school teacher. She received it 2nd hand as her college grad present in 1965. It had been in her garage since 1991 when she parked it for the winter and never drove it again.
  19. Alfster
    Alfster
    Nice........... [​IMG]
  20. bengeltiger
    bengeltiger
    More, please!
  21. Panel Dan
    Panel Dan
    from Melbourne
    Fibregl*** flip front? Tube ch***is? I don't have the time or the inclination, but I always liked the idea of a two door wagon in that shape. Shame they were never sold in Australia.
  22. bengeltiger
    bengeltiger
    What did you do on your headlights? Car looks great, nice and clean.
  23. TooManyFords
    TooManyFords
    from Peotone IL
    That white Futura is beautiful.
  24. 1971BB427
    1971BB427
    from Oregon
    Couldn't work inside anymore with the mess, so hooked up the receiver winch and pulled the Falcon out to do a thorough cleaning. Took a couple pics before pushing it back in to start pulling the engine for the build. Then I'll finish the firewall and paint everything in the engine bay before dropping the engine back in.
    Might be a driver in a month or two!
    exterminator and Maverick Daddy like this.
  25. nash510
    nash510
    from Vista, CA
  26. 1971BB427
    1971BB427
    from Oregon
    Thanks! I'm getting anxious to get it on the road! It's been nearly 40 years since I had a 4 speed car!
  27. Alfster
    Alfster
    Found this pic while looking around the internet. Anyone for a game of pool[​IMG]
  28. Leon Sandcastle
    Leon Sandcastle
    Seen that one... It was made be Counts custom in Vegas. Started as a ranchero.
  29. bengeltiger
    bengeltiger
    This guy had an idea. Found the pic on the web. Would like great in a Falcon.
  30. need louvers ?
    need louvers ?
    That's Jeem's old truck. I had my hands in that one a couple of times...
