Projects 55.2 Chevy pickup frame swap project
Discussion in 'The Hokey Ass Message Board' started by 93chevy55, Apr 28, 2013.
  1. 93chevy55
    93chevy55
    Hey guys so this is my 55 Chevy pu project I've been workin on for 5-6 years now had it all restored almost and now putting a 84 Chevy c10 with brand new 350 long block and rebuilt turbo 350 and suspension that came with the c 10 I have the cab on and front clip mocked up with a universal gas tank under the bed I will post some pics later today
  2. 93chevy55
    93chevy55
  3. 93chevy55
    93chevy55
  4. 93chevy55
    93chevy55
    ImageUploadedByTJJ1367154036.880959.jpg ImageUploadedByTJJ1367154060.831616.jpg ImageUploadedByTJJ1367154088.631192.jpg ImageUploadedByTJJ1367154104.214684.jpg ImageUploadedByTJJ1367154115.648205.jpg
  5. 93chevy55
    93chevy55
    ImageUploadedByTJJ1367154142.581436.jpg ImageUploadedByTJJ1367154176.096980.jpg ImageUploadedByTJJ1367154215.215115.jpg ImageUploadedByTJJ1367154246.831777.jpg
  6. Woob
    Woob
    from Falcon, CO
    It's coming along nicely. I'll be watching.
    FWIW: My '58 is on an '82 crewcab.
  7. fortynut
    fortynut
    My recollection of '55-'57 pickups is that they're narrower by comparison to the '76-'88. I've owned pickups from both series, and dismantled more than a few of all of them. If you just sit the body over on the later frame, the tires stick out too far and it looks like a cartoon truck. A very competent body man here in town did one that way, and I kept thinking of the Disney movie every time I saw it. Back in the eighties, I built a '57 with a Firebird front clip, nine inch and later engine/trans, and it drove like a new one. I went so far as to change out the rear springs and drilled and bolted on a set from a '76. It was a big improvement. I have a long wheel base '57 under the carport that I'm going to tackle in the future, and if there's some trick to narrowing the width, please, share it.
  8. 93chevy55
    93chevy55
    The front tires seam a little wide but after I get the ailment done i may just change wheels and hopefully brings the front in but that is latter down the line the rears seems perfect also the tires are kind of wide so ill will putting slimmer ones on ill keep posting when I can
  9. 93chevy55
    93chevy55
    Some more pics ImageUploadedByTJJ1367331104.089265.jpg ImageUploadedByTJJ1367331151.089405.jpg
    Took clip off to do some more t******* of the inner fenders
  10. 93chevy55
    93chevy55
    ImageUploadedByTJJ1367332083.416063.jpg ImageUploadedByTJJ1367332117.931696.jpg
    Just a couple when I first got it tear down and first mock up she's came along way
  11. I have a 59' Apache on a 91' frame and running gear. It actually fits ok, but is about 1.5" wider per side than I would like. I am not lowering this one to the ground, and will be running narrower tires on the front, so I am not worried about it.
  12. 93chevy55
    93chevy55
    Me and my dad were looking at it and we are thinking the narrower tires with an off set will work I am going to get "smoothie" rims so it looks like the 50 s and the 84 off set is in so hopefully pushing the off set out will bring the rim in more right now I'm trying to get front clip lined up to mount transfer cooler and firing up the 350 for the first time
  13. 93chevy55
    93chevy55
    Does anyone know the break in specs for a gm good wrench 350 long block or a site that shows the specs N break in period
  14. 93chevy55
    93chevy55
    New aluminum radiator in
    ImageUploadedByTJJ1368385237.527988.jpg ImageUploadedByTJJ1368385246.105541.jpg ImageUploadedByTJJ1368385254.854416.jpg
  15. raidmagic
    raidmagic
    Great looking truck Keep plugging away.
  16. 93chevy55
    93chevy55
    ImageUploadedByTJJ1368544561.337060.jpg just thought these kind of pictures look bad ***
  17. 93chevy55
    93chevy55
    ImageUploadedByTJJ1368544621.721086.jpg ImageUploadedByTJJ1368544629.952886.jpg
