Willys 38-41 axles differences??
Discussion in 'The Hokey Ass Message Board' started by txcr13, Apr 27, 2013.
  1. txcr13
    txcr13
    Is there a difference in 1938-41 Willys car and pickup front beam axles?
    I am looking for one for a car, and was wondering about possible differences in kingpin width, spring mount centerlines, shape, thickness, etc??
    Any help with the difference (if any) would be appreciated.
  2. Hot Rod Willys
    Hot Rod Willys
    from Ohio
    None that I have seen, just hubs, brakes were different.
  3. What he said...
    Have seen some difference in the tie rod ends, but doesn't seem to effect the axle placement, and use.
    g-willys
  4. cheap-thrills
    cheap-thrills
    37-38 have 1" more drop than the 39-42, The 37-38 use a dog-legged tie rod end for spring clearence. Also there are 2 different in the shock mounts.
  5. ME.GASSER
    ME.GASSER
    37&38 axles have more drop. Thats why they have a drop in the tierod end. Its obvious if you lay them side by side.
  6. txcr13
    txcr13
    Thanks, gents. I appreciate it.
    Any more information will be welcome.
