1957 Chevy Head ID question
Discussion in 'The Hokey Ass Message Board' started by Duke, Apr 21, 2013.
  1. Duke
    Duke
    I have a set of Canadian heads with the numbers 3731554HC on them. I can find the number listed as 2 barrel heads, but what does the HC mean? Could they be a Canadian power pack head?
  2. Duke
    Duke
    Does anyone have pictures of the casting marks on 57 chevy power pack heads?
  3. DrJ
    DrJ
  4. fleet-master
    fleet-master
    I have some 1816887 heads for 283. I've been told (on here) they are Canadian power pack heads. But there could be more than one variant I guess
  5. 56sedandelivery
    56sedandelivery
    Seems to me the Canadian Power Pack heads had a small single hump instead of the triangle. Can't help with the HC. Butch/56sedandelivery.
  6. TexasSpeed
    TexasSpeed
    from Texas
  7. Duke
    Duke
    Thanks guys, I am going to compare those pictures to the heads.
  8. Duke
    Duke
    They have a rectangle with a single hump on them (not a triangle).
  9. 56sedandelivery
    56sedandelivery
    I was right! That's a switch for a change. Butch/56sedandelivery.
    Always wanted a pair of those, and being that B.C., Canada is't that far away from me, I'm still hoping. They also say CANADA cast in between the valve springs. I'd like to find a pair of the CANADIAN Pontiac (SBC) valve covers also.
  10. Duke
    Duke
    I will try to post some pictures. I have a really nice set of the Pontiac valve covers that will be covering these heads. It is strange that they have the same part number (except for the HC) as the US low compression heads.
  11. Duke
    Duke
    ImageUploadedByTJJ1367125327.189496.jpg ImageUploadedByTJJ1367125346.998853.jpg ImageUploadedByTJJ1367125366.953788.jpg
    Here are the heads. Do the look like power packs?
  12. Nope, the chambers look like the US low compression heads.
  13. CJS
    CJS
    Duke, the heads in your photos came on 210 HP, 327 engines in around 65-67. They had a small 2G carb.They were mostly used in the lighter weight chevys. Compression ratio is about 8.4 on the 327 with flat top pistons..
  14. 56sedandelivery
    56sedandelivery
    Someone sent me a PM about a set of these heads he had, but I begged off. Well, I've thought about it, and reconsidered; send me another PM as I deleted the earlier one. Thanks, Butch/56sedandelivery.
  15. Bob W
    Bob W
    from Here
    1957 chev 283 2 barrel carb heads. I also have a pair. There was also another set of 283 2bc heads with a double bump in 57. The heads were cast and built at McKinnon Industries .
    Pic attached.
    Bob
  16. Duke
    Duke
    Too bad, I really need some powerpack 57 or 58 heads.
  17. Bob W
    Bob W
    from Here
    I'm off to a Flea Market this weekend. Do you want me to look for them ? What are they for ? A Chevrolet or a Pontiac ?
    Bob
  18. 52ragtop
    52ragtop
    from Nebraska
    With the offset valve cover screws, I don't think they are off of any 327 Single bump would say 327 but the offset screws say pre '59 283
  19. Bob W
    Bob W
    from Here
    The change in valve cover bolt patteren was mid 59 production.
  20. CJS
    CJS
    52 ragtop, you are correct, I missed the offset valve cover bolts, never on a 327. My bad, CJS
  21. HEATHEN
    HEATHEN
    from SIDNEY, NY
    At least in the U.S., '57 power pack heads have a casting number ending in 539.
  22. Duke
    Duke
    I will keep my eye out for a set of the powerpacks for a 283.
    Thanks guys
  23. Shouldn't be too hard to find- they show up regularly at our (Brad54's) local swap meet.
    If you DO have trouble, let me know and we'll grab a set for you.
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Bob, can you post the casting # off that head please. Just had a conversation with a club member about DBL Hump 283 Heads that had 1.7 approx size Int. Valve. I said never heard of such a set. The hump on your pic. clearly differs from the 327 1.94 and 2.02.
  25. Duke
    Duke
    Thanks guys. If I can't find a set locally I will see what you guys can find.
  26. Bob W
    Bob W
    from Here
    3731556 1957 Chev 2 barrel head, off set bolt pattern VC bolt holes.
  27. Bob W
    Bob W
    from Here
    Are you building an original 57 Chevy ? If not the 520's are a better casting 283 head. Mid 60s.
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Thanks Bob
  29. Duke
    Duke
    I need the offset bolt pattern to fit my Canadian Pontiac script valve covers.
